help
  • Thread starter Thread starter jimmy Paige
J
jimmy Paige
I need help and ideas. trying to remove flywheel on zl 600 , bought universal clutch holder and removed clutch thought it would work on the flywheel/ magneto. It seems stuck
Borrow the proper rotor puller from a shop. The Kawasaki tool is 57001-1216. It simply screws into the center and pushes against the shaft so any puller with the same thread will work. Just don't beat on too hard if it's stuck.
Thanks, I can get the puller no problem the bolt holding in on was super tight. I got a chain wrench that would wrap around the flywheel to hold it still.
Sorry, I misread your post. You could also put it in a high gear and use the rear brake.
that is a great idea, but the motor is out of the frame. I hade to replace the starter clutch gear. this bike has 6800 original miles on the motor, My gramps bought it some years ago and it has sat under his carport. It needs TLC. i have ridden this bike but it has been more than 10 years. I have no idea when the bike last ran. When taking off the carbs I discovered that the fuel adjustment screw housing was broken.
So any help from here is appreciated. i want this bike to run again. I remember it being pretty fast
Thanks for the info, I looked at the one in the blue case. update I got the motor back on the bike, the starter clutch gear replaced and working much smoother.
Took the valve cover off and everything looked good, just a slight burnt smell, should I bee concerned
Also, looking at the exploded clutch view dose the pusher or go in front of the pressure plate or behind
Okay, folks. I have split the case on my bike and replaced the starter gear and clutch, put it all back together snd the transmission will not change gears. any advice is appreciated.
Do you mean the clutch isn't working or the shifter won't change gears? Did you split the cases or just remove the side covers? Splitting the cases means you had the engine out. Not lining up the lever on clutch cover when putting it back on is a common mistake.
Reread your posts. The thing you can check without splitting the cases is the shift paws. If those are right, you'll need to open it back up.
