ZL600 throttle cables
  • Thread starter Thread starter old-edd
  • Start date Start date
O
old-edd
I'm nearly there with this rebuild, but I only have a pull
cable fitted (I'm not that brave) and its in a poor state (frayed, twisted, kinked).
I can find plenty for the GPZ 600r but I cant find a pair of zl 600 cables in the UK
so I wondered if any other models had cables I could use.
regards
Edd.
Hi I'm new here, and I dont know how to use this site yet ( how to make a post etc) . Can I ask you if is it difficult to find parts for this bike? I'm thinking about purchasing a zl600 1996 ....Sorry for my bad english and thanks in advance for your reply....
Welcome. Not sure about finding parts in Italy. Maintenance items like fork seals, filters, carb parts and such should be redily available. Body parts if you need them may be hard to find, keep the shiny side up.
They are nice bikes that you don't see everyday. If you don't mind a bit of maintenance on an older bike they are solid bikes. Good luck on your decision.
Thank you. The bike I m interested in was parked for a long time. It has only like 8 thousand km on it...I'm only worried about carb parts, oil filters, brake shoes and parts like that, i hope i will not need soon any body parts.. .
As far as throttle cables for the ZL600, I went online and bought cables that you can make the same length and has worked great for my 600.
Partszilla was my 1st call, they say one is unavailable,
I have seen cable make-up kits on line but the ends don't
match the bar control fitment.
I assumed other owners would have needed cables, and if
unable to source may have found an alternative.
Many thanks
Regards
Edd.
Hey guy you can go online with Ebay like I did and get your cables. The repair cables are 40 inches in length that work fine for the ZL600. I have been using them now for over 2 years and no problems. They are sold by chennan888000-9 out of China. They are just a few dollars for each cable. Not bad. Just pull the old cable out and rethread the new one in the old sheath. They give you several different end connectors to choose from for your particular bike.
Iv just ordered a push/pull cable kit from Venhill here in the uk
they have new sets for near all Kawas but not the zl600, they say
the kit Iv ordered can be adapted to suit, just got to find my solder-iron.
I will up-date on progress, thanks again gents for the input.
Regards
Edd.
I just went on EBay and they showed the cable I was referring to for the ZL600.
I have tried the soldered type but the solder doesn’t hold up so I went to the screw in type that really works.
Cottontop, the solder type works fine. You have to spread out the wire ends like a flower after you slip it thru the brass barrel and before adding solder or it won't hold. Grind the excess strands off so it fits and you're done. I never had one pull out.
If the barrel has a slot across the hole, you spread the wire ends out across the slot like a "T" before soldering. A lot of stock cables use that type.
The ones I got to solder did not have the slot across the barrel so I finally got the screw type ends that are easier to use and install.
To be honest I didn't ask if the nipples were screwed or solder,
Iv soldered clutch cable ends before (as per Eds method) and not
had a problem (famous last words).
Hey guys, on Ebay, the seller for the cables that fit the ZL600 is now sun.changde out of Shanghai, China.
