Grips ordered
I wouldn't bother with a barsnake. I put one in the 900 and saw very little difference in the vibes. The bad thing is if you don't like it, it's in there. I'm sure there's some way to get it out - acid or something maybe - but not worth the hassle. Others have suggested using bb's or something like that so you can get them out if you don't like it. Wire like a battery cable was also mentioned. Just my experience with it. Later.
Thanks Jarney, maybe I will try and old battery cable next time I have the grips off for some reason...Won't hurt anything to try.
does it affected grabbing the brake handle in emergency situations? NO
Also does it slip enough to shut down the throttle quickly? you have to roll the throttle forward, so it's not instantaneous
What size did you order 7/8 or 1"? 7/8
