Rhamah
So I took my zl600 to the shop to have them look over my handiwork (after working on it myself when I could get back home to it) and sync the carbs. When I was pulling in, the radiator dumped and wouldn't suck the coolant back in so I had them look at that too. Ended up requiring a new radiator cap, so no big deal.
Cue 4 weeks later I finally get it back and it runs pretty good. Until I hit the city driving that is. It doesn't like to idle (RPMs too low), so I'll move the idle screw and then at the next red light it will be too high. If I'm in too much stop and go it will dump the coolant to the bottle on the outside and tell me it's too hot, then the revs will shoot up and stick at around 5k even if I put it back into gear and let it bog down, it will just shoot back up again. Also I'm on the RES tank at 75mi, and out of gas completely at around 100. Is that normal?
My question is whether I should bring it back to the mechanic and have them look at it again ($$$) or is this something I may be able to diagnose and fix with my screwdriver and socket set in my apartment parking lot?
Things to know:
-1986 ZL600
- K&N filters
- Jetted Carbs
- California tank on a non-Cali bike
- Tank recently stripped and re-coated
- Petcock recently rebuilt
- Carbs just synced, and cleaned (once by mechanically inclined friend, then later by actual paid mechanic)
- Radiator tested, no leaks
- Usual commute is 2 miles stop and go, then 10mi highway, then 2 miles extreme stop and go. (reverse for ride home)
- Starts pretty good (with choke)
Things to know:
-1986 ZL600
- K&N filters
- Jetted Carbs
good work!!! glad you got her fixed!!
