zlMark
Cult Leader
Glad to have you guys out!
Here's a few pics I took:
Furchin and Gremlin
Here's the result of the factory petcock not sealing and float valve not sealing. See the bent #1 conn rod? ...well known problem on these motors and it's called hydro-lock. This bike really sounded like something was banging in the valve area.... Compression check revealed #1 was low. Oil pressure normal so we decided it was time to take the top end off and have a look and save from looking in the oil pan.....As Jimmy Carey said as The Mask...."Hold on to your lugnuts, it's time for an overhaul!"
Gremlin on the left and Furchin on the right.
Markus 56 and Furchin with a garage full of bikes
Furchin and Gremlin
