stick coils?
vinny Dec 28, 2007
Tags:
  1. 87kawzl
    87kawzl Well-Known Member
    974
    27
    The coils vary greatly in price, I searched z1000 and found that you could piece together coils and harness for ~$35 shipped. This is turning out to be an affordable mod if the bike is hit and miss on cylinders firing.
    6,781
    125
    108
  3. 87kawzl
    974
    27
    Is the pigtail long enough on the harnesses to just switch plug ends?
  4. Breeze
    Breeze Active Member
    68
    43
    It looks like it should be. I plan on cutting the ends off the ZL wire and he harness and using a GM connector kit from Napa, exactly like RJ said.
  5. Breeze
    68
    43
    Well I got some '06 ZX14 coils last night. They are used, but all test good within the factory specs. However, all four coils measure 1.5ohm on the primary side. From what I have seen, the factory specs are 1.2 to 1.6 ohms. If i put two in series, these would total 3.0 ohms, which is higher than the 2.8ohms that the ZL900 calls for. Will this increased resistance have negative effects on the ignitor?
    If so, I guess I could wire them in parallel and add a 0.5 to 1 ohm resistor to each positive cable leading to the coil. Thoughts?
  6. kawboy
    I have seen this discussed on other forums, and some believe the stick mod does not deliver as hot of a spark as "regular" coils. However, this mod has been around a while, and have not heard of any problems.
    6,781
    125
    108
    :hello: So who bought the stick coils from post # 182.
  8. prfixer
    1,259
    0.0 Ohms equals no resistance. Taking something with 3.0 Ohms and adding a 1Ohm resistor gives you now a 4 Ohm resistance rating.
    6,781
    125
    108
    :hello:If a circuit has 4 1.5 ohm resistors in parallel the total measured resistance is 1.5 ohms. When resistors are in parallel the total resistance measured will not exceed the smallest resistor. When resistors are in series the total measured resistance is the sum of all the resistors. One or to ohms of resistance in a circuit will not change power output all that much. Remember voltage in a bike when running will range @ 12.8 to say 14.8 VDC. Attached is formulas/equations for finding Voltage/Current/Power/Wattage & Resistance. IMG_5387.JPG
  10. Breeze
    68
    43
    Well, if the factory specs call for 1.8 - 2.8 ohms and I wire 1 & 4 in series and 2 &3 in series with the ZX14 coils I have, the resistance comes out to 3.0-3.1 ohms. Will that 0.2 - 0.3 ohms make any difference? However, if I wire them in parallel and add a 0.5 - 1.0 ohm resistor, then the resistance should measure 2 ohm, and then I should be okay. Correct? The next question is how big of a 0.5 - 1.0 ohm resistor? 50 watt?
    If I were to wire them in parallel without any resistor, they would only be 1.5 ohms, which is 0.3 below the factory specs. I assume this would not be good on the CDI. Correct?
  11. Breeze
    68
    43
    Oh, I'm not being clear. I apologize. My question involves wring the coils in parallel with a resistor on each circuit in series.
  12. Breeze
    68
    43
    So you're saying that if I wire them in series, even though they are only 0.2 ohm above ZL900 spec, it should only make a very minor difference, and not cause any damage to other components?
