question about stem bearing sizes for 85 ZL900
katz
Tennessee
Hi,
I wrote down these bearing sizes for 85 ZL900 (ID x OD x Width):
upper => 25 x 47 x 15
lower => 28 x 52 x 16.5
I checked All Balls Racing steering bearing size chart and I saw these sizes only:
25 47 15 => part # 99-3518-5
28 52 16 => part # 99-3513-5
Should I look for another source of stem bearings or will those work? I would appreciate any info on the matter.
Thanks,
Katz
22-1009 is the All Balls kit listed for the 900 and many other Kawasakis. It's $40 and comes with the seals. The stock bearings are tapered but costs almost twice as much. Why are you replacing them, corrosion?
Yes there is rust inside, would like to get new bearings. Thanks for the All Balls kit info, didn't see it on their website.
Tapered bearings are the way to go IMHO. Had both and would spend the extra coin, take it for what it's worth but I am cheap and like OEM fork seals you want tapered bearings.
Sorry I don't follow, that All Balls kit that Ed mentioned (22-1009) has the following included in description:
"Heavy duty tapered roller bearings"
Is that the kind to get?
Yup, if they are described as tapered you will be fine.
Make sure you replace the races, not cool to put new bearings on old races.
Thanks for the heads up, I do try to stay away from MIC parts. I didn't know All Balls bearings were made in PRC. I checked partsfish.com for Kawasaki OEM parts:
92048 RACE,ROLLER,32005JR RS part # 92047-017 - $40.89 (upper bearing)
92116 BEARING-ROLLER,HR320/28XJ part # 92116-1009 - $39.86 (lower bearing)
Both include races.
:hello: When I did my ZL 1000 steering stem bearings 10 years ago I used OEM bearings. Then they was $50 for both sets. I quit using ALL BALLS bearings over 15 years ago when I wore out two sets of them in my YAMAHA Sport Quads rear axle carrier in less than two years. The same thing happened when my Sons raced back in the early 2000s.
I wouldn't worry about Allballs being Chinese for the steering head since it's a low-speed application. The problem I hear with the kits is you might get a one-size-fits-all seal which doesn't seal and that can lead to corrosion and wear. The fix is use the stock seal. Any tapered needle bearings should last forever compared to balls. OTOH, getting the right seals and better bearings for just a few bucks more, makes more sence.
So, I was looking at tapered bearings for the ball-bearinged Yamaha and it seems the one kit is common for most steel-framed bikes. There're other BR01 kits that cost less but they don't have the matching 22-1004 in the description. All BR01 kits use the same bearings so I don't know what the difference could be unless it's the seals. This is what I ordered:
https://www.amazon.com/Pyramid-Parts-BR01-Kit/dp/B07RZM6FR2
I suppose the ZL takes this kit:
https://pyramid-parts.com/products/steering-head-bearings-kit-22-1009-SSK902-BR02
