New Tools
My first one-
Looks fantastic. Is that the one they call the Mae West pump?
This one is a fairly common pump, a Gilbert & Barker T-176
This is a Mae West-
:hello: Are those pumps used out in the field or are they used for show. What do they pump.
They are visible gasoline pumps, used mostly in the 1920s before the advent of electric computer pumps. The gasoline would be pumped manually up into the glass cylinder and then delivered to the customer so they could "see" what they were getting.
:hello: I bought a new DeWalt weed eater ($370) and a 9 amp hr 20/60 volt flex battery. $250. ______________________________________ 20250706_075150[1].jpg 20250706_082726[1].jpg 20250706_082738[1].jpg
Did you buy the extra battery after you determined the one that came with it wasn't big enough?
:hello: No, Tool only. The one with a battery and charger came with a 3 amp hour battery. That would last about 20 minutes. The 9 amp hr battery lasts about 3 hours. I have 8 chargers, so I didn't need another one. :laughing7:.
I was looking at Ego. I need something that can go after the the thick brush that doesn't need the head played with every 10 minutes. My curved shaft Stihl is more meant for trimming grass.
:hello: I have a stright shaft Stihl. It's to long. I have to hold it above my shoulder. That's why I bought the DeWalt. My Son Jared moved to Minnesota six months ago, so I lost my yard guy.
:hello: I compared the EGO to the DeWalt. The DeWalt seems to be much more stout. Besides I have nine DeWalt batteries and six chargers. 20251011_061230~2[1].jpg 20251011_061240~2[1].jpg
:hello:Bought these. LOCK N FLATE 90* air chuck and LOCK N LUBE grease coupler. $40 each. Made in South Africa. I also bought a new USA made MILTON air inflator gauge. $60 _______________________________________________________________________________ 20251119_100818~3[1].jpg 20251119_100820~2[1].jpg20251119_102558~5[1].jpg 20251119_101651~2[1].jpg 20251119_102238~3[1].jpg20251119_103135~4[1].jpg 20251119_103128~2[1].jpg 20251119_103107~2[1].jpg 20251119_104953~2[1].jpg 20251119_105005~2[1].jpg
:hello: I bought a used 30 foot commercial grade flagpole for $60. New they run around $1600. It came with the black plastic ground insert. I dug the poles hole 30 inches deep and 18 inches wide. It took 210 pounds of quikrete concrete to fill the hole. Also I bought a bald eagle topper $88 shipped and a USA made Allegiance 5'x 8' flag for $ 66 shipped. https://www.ebay.com/itm/286880534879?_skw=bald+eagle+flagpole+topper&itmmeta=01KB5Q0V6F48GDRNNNMHRWGEAQ&hash=item42cb69915f:g:3osAAeSwCupo8JEB&itmprp=enc:AQAKAAABAFkggFvd1GGDu0w3yXCmi1etQUHymniYijfw2V . https://gracealley.com/collections/bestsellers/products/5x8-embroidered-american-flag . My old flagpole was 34 feet tall. The rope kept coming off the pulley. Twice I had my skidsteer guy pull the pole out of the ground. To set the flagpole in the ground first you slide the pole into the insert.Then level/plum it. Next using a water hose you slowly put sand between the pole and the insert. Over time more sand needs to be added. If the flagpole needs to come out of the ground use a water hose while shaking the pole while lifing it at the same time. To put it back in the ground you water the pole with a hose and the weight of it sucks the ploe back in the ground. ____________________ 20251128_071057~2[1].jpg 20251123_115333~2[1].jpg20250924_094428~2[1].jpg 20250924_094435~4[1].jpg 20250924_094435~3[1].jpg 20250925_113418[1].jpg 20250925_113425[1].jpg 20250925_113438~2[1].jpg 20250926_123517~2[1].jpg 20251024_113937~3[1].jpg 20251024_113954~2[1].jpg 20251123_100631~2[1].jpg 20251123_100630~4[1].jpg 20251128_130900~2[1].jpg 20251128_130835~2[1].jpg
I am slowly switching to team red battery tools with Milwaukee. Picked up an M18 grease gun a while back. Had a tough time pulling the trigger dropping that much but all those points on the Kubota_justified it in my mind. No regrets. ______________________________________________________________________________ View attachment 48023 View attachment 48024View attachment 48032 View attachment 48026 View attachment 48025View attachment 48027 View attachment 48028 View attachment 48029 View attachment 48030 View attachment 48031
I bought my second MIGHTYMAX battery for my exmark zero turn mower. Eight years ago the first one cost $55. This one was $75 shipped. This is the first battery that has lasted me over eight years here in FL. The one that came with my mower lasted only two years. My record is a Sears Die Hard that I bought for my 1973 Dodge Dart Sport in 1976. Installed it was around $22. It lasted just over 10 years. __________________________________ 20260214_105957~2[1].jpg 20250419_091253~2[1].jpg 20260214_111859~3[1].jpg 20260214_111916~2[1].jpg
This past June I bought a new 60 gal. 3.7 HP 175 PSI 240 VAC three phase Craftsman air compressor for $900. I sold my 1991 one for $375. I was tired of fixing it. I had to replumb the black steel 3/4" conduit pipe and painted it black. I made the pipe run a bit shorter in overall height and angled it more for proper drainage. The piping is 26 feet from the tanks air output to the two air chucks just after the air regulator. I used heavy duty stainless steel clamps with rubber grommets to hold the piping in place. Also I added another DeVilbiss water catcher. Both cost $200. New motorgard contaminate catcher $80. The filter in the motorguard looks like a roll of toilet paper. The manual air hose reel cost $40. Two new quarter turn 1/2" shut off valves. $12 each. The drain for the compressor was this 1/4" junk gismo with a spring. It took 10 minutes to undo it to drain the air/water from the tank. I drilled out and tapped the bottom of the compressors plate for a 3/8" drain. Now it takes five seconds to undo the drain. I also repainted the compressors cage/craddle. The casters are from an old grocery cart. The hardest part was getting the compressor into it's craddle. Total time spent around 12 hours. The new Craftsman is much quieter and fills up twice as fast as the old compressor. 20260616_115042~4[1].jpg20260616_115018~6[1].jpg20260616_114926~6[1].jpg20260616_114951~6[1].jpg20260616_115102~4[1].jpg20260616_115139~3[1].jpg20260914_141256~3[1].jpg20260914_141436~3[1].jpg20260914_141524~3[1].jpg20260914_141400~3[1].jpg20260914_153833~3[1].jpg20260914_141410~3[1].jpg20260914_142612~4[1].jpg20260914_141609~2[1].jpg20260914_142410~3[1].jpg20260914_142906~4[1].jpg20260914_141617~3[1].jpg20260914_141633~3[1].jpg
Thats a heck of a cart. That's one way to get the noise out of the garage
