Steve C
- Oct 29, 2013
Hey folks,
So I am really hoping you guys can help me out. The other day I was adjusting the valves on my 86 ZL600 (which 15 of 16 were significantly out of spec btw) and to rotate the engine into position I was bleeping the start button. My problem likely arose from the fact that I forgot to disconnect my trickle charger before bleeping away, and after a few bleeps my headlight quit. Not thinking much of it, I assumed I had either blown the bulb or fuse. However, after checking with the multimeter I found that the headlight plug and even the headlight circuit in the fuse box had no juice at all. I did check to see that at least the tail light circuit still had juice but since the bike will turn over and all lights work, I figured it was only that headlight circuit. t
I have looked at the wiring diagram but I can't seem to make out where else in line I am losing power between the battery and fuse box for only that headlight circuit. If anyone can help me out I would REALLY appreciate it!!!
