joealso
Well-Known Member
Thanks to several of you (Ian and Paulfun, particularly), i was able to change my waterpump a few months ago. Now i have a new problem - a leak from the metal (inlet?) tube where it connects to the pump. I took everything apart and back together - made sure it's all tight, but it still leaks. Then i took it all apart again and stuck a rubber o-ring on it and tightened it up again - no better. I'm hesitant to try putting Permatex around it. Any suggestions?
