joealso
Well-Known Member
I'm not a mechanic by any means but i'm using both service manuals and i'm almost done. Two questions:
1) When reinstalling the new water pump, i did my best to visually align the female shaft on the new pump to the male shaft on the engine, but i'm nervous. Am i safe to assume that if the pump fits in snug and bolts up that the shafts are aligned inside?
2) It seems that whenever i attempt to fix something, i inevitably break something else in the process. In this case, when i popped out the old pump, i snapped a wire leading down to a sensor just below and to the right of the pump. I'm assuming it's the temperature sensor. The same bundle of wires also leads further down to another sensor which i assume is the oil sensor. Normally, i would just splice in a new wire, but where it snapped was inside the right angle rubber boot. Any suggestions?
Thanks,
Joe
Thanks,
Joe
