Plug wire help
  • Thread starter Thread starter Bliz68
B
Bliz68
Hello all. Just picked up a 97 zl600 to tinker with over the winter. It would start and idle but would bog down hard at any throttle. So I'm taking it down and going to replace, refurbish and rebuild. Already did minor maintenance. Now I'm working on ignition system. With the help of this site, I've disassembled and cleaned all the plug caps. All the resistors seemed in spec. My question is going to be on the other end of the ug wires. The coil end. I unscrewed those little caps and pulled the wires out. My confusion begins there. The end seems to have some kind of cap on it. How does that come off to inspect the wire ends? Thes seem to be on there pretty firm. Do I pull them off? Twist them off? Don't wont to break anything. I've searched so many threads my head hurts. Lol. I found alot about the plug cap ends but mot the opposite end. Thanks for any and all help.
You can't do much on that end other than check the wire's resistance. Nothing else comes apart. I like to use a light silicone lube inside there before reassembling to seal and protect from corrosion.
What would a person do to that end if they're making new wires?
IMG_9608.JPG IMG_9609.JPG :hello: Cut the old spark plug wires as close as you can to the rubber grommets and slide them off. When putting them on new wires slide them on the same way that they came off using a bit of lube. Use stranded 7 mm copper core wire and not the single core wire. I use PRECISE USA made plug wire. You can buy it from AMAZON for $17 for a 10 foot roll. https://www.amazon.com/1867-SPARK-P...er+core+spark+plug+wire&qid=1609593511&sr=8-2 .
They pull off. If they get buggered up and can't be put on your new wire (7mm) use an O-ring in its place.
