Odd Starting Issue
ZLrider
Hate to admit it, but the bike has sat for 2 weeks since I last took it out. Wouldn't think that should be an issue.
So I get on the bike hit the key. Get a gentle whirring sound. No start. What the hell? A few more tries. Bike ever so slooooowly turns over. Check the volts, 12 at the terminals. Well that ain't right. Put it on the charger for an hour or so. Hit the key. Varoooom! Running in two revolutions of the starter. Volts right off the charger: 16! While idling: 15. Rev it up, falls to 14-14.5. Seems kinda odd, but still plenty to keep the batt charged.
Shut it off, restart. Repeat. Shut it off, check the batt again: 14v. Load test the thing. Volts fall a little. Give it a really long load test. I can smell the tester heating up. Check the voltage. 13.5. Still, she starts right back up. 15V again. Shut her off. Restart, repeat a couple more times. Still have 14V at the batt.
Pulled it out to check electrolyte. Cells all fairly full. Battery is 4 year old, but still it seems to be doing the job. Almost seems like something may be drawing it down very slowly, but what? Do CDIs draw power when the bike sits?
A short/ground/Earthing problem somewhere? Or the regulator/rectifier on the way out? I had the circuit board in the fuse box cause problems with damp infiltration.
Where is the regulator and can it be tested? Is it normal for the charging volts to go down and level off as the revs pick up?
:hello: TROJAN: Do you have a thin 20 gauge black wire tied into your batteries grounding wire at the battery from the factory. If not add one into your wiring harness at the nearest black/return wire. You might have a floating ground. I added two grounds to my ZL 10. One at the fuse boxes nearest return/black wire and one at the CDI/ECU nearest return/black wire. My ZL 10 retifier was over charging to 18 VDC. On the ZL 9/10 the retifier is built into the starter. I upgraded to a 2004 ZRX 1200R starter. Here is a NOS ZL 600 battery cable. https://www.ebay.com/itm/321226526587?hash=item4aca97cf7b:g:jsUAAOSw3mpXIkYA .
Battery is probably on its way out. 4 years is a pretty good run for a lead acid battery. Get yourself a sealed agm battery.
Thanks for the tips. Got a bit more data to add. After sitting overnight the batt read 12.7V. Seems about right. Put it back in, bike started right up. After a 45 min ride it still would pop right over like a champ. Checked the batt: 13.7V. Seems again to be pretty much what it should be. Checked for a draw and found it is pulling 200 mV. Seems like not very much, but my HS electronics class was a long time ago. Is this normal though? If I had a hot wire shorted to ground I'd think one of my lights would be messing up or I'd be blowing fuses....weird.
Yeah I know, changing the batt would help, but the damned thing loads like a champ still.
Oops, I meant it's drawing 11 on the 200 mV scale. That seems like almost nothing to me, but what do I know. Can anyone confirm that a small draw is normal?
A USB connector with nothing plugged into it will kill a 14AH Yuasa MF battery in less than a month. Not just too low to start but zero volts. The battery should show no parasitic drain.
I think you mean mA? With everything off, it should be unreadable on the 200 scale.
I guess maybe I should have measured amps, but I was just looking to see if there was any drain when it seems like there shouldn't be. I'm also not sure that my meter is all that accurate. It almost seemed like it wanted to shove a few mVs when it wasn't hooked up to anything. Guess maybe I'll try again with the meter set to amps.
I also was thinking 11 mV was close to nothing, but why the hell am I getting any reading at all I wonder. So there is nothing that should be drawing power with the key off, correct?
Remove the positive lead from the battery so you don't blow your meter and measure resistance/ohms at the cable ends. You can chase down the problem checking along the postive up to the ignition switch where it should be an open circuit.
I always set my meter back to volts because it'll blow the fuse if I forget and have it on amps or ohms when I go to check voltage. :mad:
:hello: My fluke has never blown a fuse. It's a first gen FLUKE 77 from the early 80s. It's been threw hell hand back. Once it fell forty feet while I was on a Navy Destroyer. Something rattles inside. :laughing7:.
Seems Flukes are almost legendary, but I've never had one. Been relying mostly on an analog I got at Radio Shack long ago. It has served me well, but seems a little wonky now. For some reason I just really don't trust the digital ones either. A needle on a gauge just seems more real than some numbers on a screen. As for fuses, I'm in the same boat as Ed. I've blown a whole lot of fuses even though I try to remember to always set the selector to off after using it.
:hello: I also have a 1960s Radio Shack analog multi-meter that I got from work years ago. It's big and heavy. You can find the old USA made FLUKE 77s & 87s on E-bay for around $70. They are made better than the new FLUKE imports.
Well it's been pretty wet.....and hot. Haven't done anything with the bike since the last time out. Guess I need to test the batt again to see if once again it's gone flat. I'd like to think it was just a FLUKE (pun intended!), but I suppose that's wishful thinking.
Sat for a week, same crap. Talked to Bill and he said no draw is possible with the key off, so not sure what the hell to make of that small voltage I measured. Static charge? I dunno. Puzzling. I'd like to check it again measuring amps. Do I just stick the meter in series between the cable and the battery?
My current thinking is the batt must be internally shorted. I'm going to let it sit disconnected until Mon. If it goes down again I'll know it has to be the battery. Funny though what a great charge that thing will take and hold. Basically just like it did when it was brand new out of the box. That's seems puzzling too. I'd expect a dramatic drop in performance considering the age.
:hello: Just get the battery tested. I have this Battery Tender tester. ($40). I got it for XMAS a few years ago. I lke it because it's old school analog. 20210821_121059[1].jpg 20210821_121022[1].jpg
I've got a Schumacher that is nearly identical to that one. It works well and shows the battery to be every bit as strong as when it was brand new. Yet, the bike won't start after a few days. My last tender made the battery gas and if I didn't keep a close eye on it, it actually KILLED my batteries prematurely by exposing the plates. As you prob know once plates get exposed to air, they'll never work as well as they once did.
I really hope when I check it again tomorrow that battery has gone flat while disconnected. Otherwise I'm at a loss how the charge could be bleeding off.
:hello: Quit buying lead acid batteries. I'm slowly going to lithium ion batteries. I've had one in my sport quad now for 7 years.
