zlMark
Cult Leader
May as well check out all the sparkplug boots and make sure the springs are in the ends and the screws in the other end are good. Replace the plug wires with bulk copper core 7mm. This is easy and you use the existing plug caps and compression fittings on the stock wires. Do not use graphite coreActually, I turned her over with the carbs removed and stuck my hand over the ports - good suction on all. I think Billy was on to something with the comment about the plugs. tested the spark on all of them. All sparked steadily but not particularly strong. I'm now wondering if the uneven running is electrical.
