Looks good. Shed looks to be 12'x 16'. Shed needs to be cleaned after making that 90 mile trip. My Wife and I are from Northern Cambria. We both went to School at Northern Cambria High School. Barnesboro and Spangler joined together to become Northern Cambria in January 2000. It's population went from 12 K to 5 K after the Coal Mines and Steel Mill all but disappeared.
Are you going to run electricity, insulate and finish the walls inside like I done with my Bike Shop. You should paint the bottom edge of the Siding so it doesn't rote.
Nice!!! I forgot that you had a basement. Not many homes in FL does.
. Some bone head cut me off and I spilt take out sause on the seat.
I don't remember what brands the other two where. They both leaked while being used.
Yesterday I got my throttle cables, carbs, air box to carbs duck boots and new stay springs back on my ZL 10. (3 hrs) Tomorrow I'll try out my new sync gauges.
I bought this VEVOR motorcycle hitch hauler model # TD-1004-08 for $210 directly from the manufacture. I did not like the location of the mounting points for tie down straps so I bought an 8'x 1" boxed aluminum rail. I also bought four S.S. eye hooks. The people at LOWES though I wanted an aluminum box.
. I cut the rail into two four foot sections and mounted them on the sides of the hauler using S.S. carriage bolts. I added cut to fit reflector tape on the three exposed sides. ____________________________________________________________________
![20240816_140257[1].jpg 20240816_140257[1].jpg](https://www.zl-oa.com/community/data/attachments/31/31815-7543394591a3643493415387fcd53895.jpg?hash=dUM5RZGjZD)
It's rated for 600 pounds which is what my hitch tounge weight is rated for.
Today I bought this PITTSBURGH wheel truing jig and dial gauge from Harbor Freight. The base is magnetic. $35 for both. It should be good enough for truing motorcycle rims. I priced other units they run between $70 to $120. https://www.harborfreight.com/multi-position-magnetic-base-with-fine-adjustment-63663.html. https://www.harborfreight.com/1-in-travel-machinists-dial-indicator-63521.html .
![20240818_103653[1].jpg 20240818_103653[1].jpg](https://www.zl-oa.com/community/data/attachments/31/31817-bc52a891342253742fabf9fe7c403ae6.jpg?hash=vFKokTQiU3)
I also pulled a permit for my shed/shop. Total cost was $30. I did not pull a permit for the electrical.
