Rhamah
My ZL is letting me down
To be fair, I let her down first and she's just paying me back. I haven't been able to give her the love she needs thanks to a new truck, new wife, and nowhere to work
First thing I did after winter was over is ride it. Was a little rough so I ran a can of Seafoam through it and it ran better for awhile. Checked the oil/final gear oil/and had the battery on a tender all winter. After the first few rides it went downhill, ending with the last few times I've attempted to ride to work and it won't start. It'll turn over just fine... until the battery dies. Then I hook her up to the truck and finally get it going.
Next thought was the battery/connections. Pulled the battery cleaned up the connections and sure enough, it was low on acid. Bought some more, filled it up, and ran it for a bit. Still had trouble starting in the morning but it was slightly better.
In the past, as well as being hard (impossible) to start, it will stall and die at red lights. Usually, it would always start back up. Not the most recent 2 morning commutes though. I would have to push it to the top of a hill, and push-start it. I thought maybe I just wasn't driving it on the freeway enough and the battery couldn't stay charged since the first and last parts of my short commute are usually stop and go traffic. But that didn't sound right.
So me and the wife (she's new, still runs great) are riding and I feel it trying to stall. So I pull into Autozone to test my "bad battery" theory and have them test it. They say it's coming up a little under 12v, but the diagnostics machine is saying I have a bad voltage regulator. So I buy one from a somewhat reputable eBay dealer and install it. For it being only one connector, and two screws, it was a surprising pain in the ass. It rains the next week so I am not able to test it. I hook it up to the truck for a bit to give it some juice.
Then this morning I try to take her to work once again and we go through the same routine. Won't start, turning over until it dies. (not constantly with my finger on the button mind you, 3-4 second intervals until you could tell it was dying). I hook it up to the truck and it starts. I let it idle a minute or two still hooked up and take off. Then it stalls about 2 miles down the road at a stoplight. I should mention this time, the Tach wasn't working when it started. I get to the top of the hill, push start it, and magically the tach starts working again.
Here's where I'm thinking the problems may be:
1. Bad battery. (possible, it's only a couple years old but it was an eBay buy)
2. New voltage regulator is a POS. (possible, but not likely)
3. I've got one of those gremlins in my electrical system we all love. (please no)
I'm really hoping someone tells me it's a random $5 part that will fix all my problems and get me +100HP and an extra 30mpg. AND is installed by 3 screws right under the seat.
You can disconnect your battery & charge at 2 amps over night. Then check the voltage. Let it sit for 3 hours or so. Check the voltage again. If it drops below 12 volts replace the battery. Most of the time when a battery looses its acid it can't be revived for very long. My charging system in my bike is as follows with new battery. Battery sitting over night 13.2 volts. Hit the starter voltage drops to 11.5 volts. At 2000 RPM or > the voltage climbs to 14.4 volts. Not all batteries or charging systems are the same but these # will give to a reference/starting point.
