Chikara
Well-Known Member
Hi guys. How are you all doing? I've been off the forum for quite a while because, well, I live in Michigan and my ZL9 has been in storage forever.
Anyway, I bought a +4 degree performance advancer from MCM last year but never got around to installing it. I did it a couple of days ago and noticed when I pulled the cover off that the old gasket (looks like the cork kind) was stuck to both sides--the plate and the housing--but it was in big chunks that simply did not want to come off. I tried my best scraping with a scraper and with a knife but my best didn't seem good enough because there were still chunks of it on both sides.
I replaced the old timing plate with the one from MCM and then replaced the cover with a new gasket. After doing so, I ended up with oil leaking from between the cover and the engine. I then removed the cover and took my dremel with a wire brush and buffed the remaining pieces of gasket off. This may have been a stupid thing to do but I'm not very experienced with this stuff, so it seemed like a good way to get the gasket off. I also checked the new gasket for damage and it seemed to be clean and scratch/dent free.
I have replaced the plate and the leak is much smaller, but it's not completely gone. I don't think there is any more gasket I can remove, as I was seeing silver all around. Now I'm wondering if maybe I didn't screw myself and now there is nothing the gasket can do for me.
I have a couple of ideas of how to remedy this, but rather than spinning my wheels, I thought I'd ask for some opinions.
My ideas are:
1) The gasket I bought was really thin and kind of cardboard-feeling. Would buying some thicker cork-type gasket material and cutting out my own gasket help?
2) Should I use the same gasket but add a bit of gasket sealer to it?
If any of you have experience with this or if you have a good way of sealing up an oil leak, please let me know. Also, I am open to any and all beratings for using the dremel.
My ideas are:
Indian head used to be just that AFAIK...I remember my Gramps telling me it was good stuff.
