blackzl9
Well-Known Member
- Jul 20, 2008
back this spring i was having trouble with my headlight going off whenever it felt like it.well,i feel stupid but i overlooked something while diagnosing it.i had pulled all fuses and relays,cleaned contacts,rewired the headlight,got another reserve switch,still didn't fix it.well,i got messing around with the 3 relays in the fuse box.i couldn't get the headlight to turn on,so i swapped the relays around. i swapped them around and then it wouldn't start.so i swapped it back and it started but still no light.swapped it back again and beat on the relay while holding the starter button and after a couple good raps it started.so,there you have it.
checked out ronnies.com and it's 50.00 for the relay #27034-1006 hope this helps somebody! shawn
