Exhaust gasket advice..
perry
I have an exhaust leak where at the bottom of the ZL where the left & right exhaust meet. I believe there is a small gasket that is installed at this intersection. A clamp holds the pipe to the gasket. Is there an "easy" way to replace this gasket? I dont want to drop the entire exhaust system for this one piece.
Thanks!
Yes, there is a gasket in there and yes, you will drop the entire exhaust to replace it! You will also need the four copper gaskets at the head since they shouldn't be re-used.
Actually mark if your patient you can finesse the outer down pipes out and replace the gasget on them without removing the center pipes. I have done it so I know its possible!
