acevmp
Hello all! I'm new to the forum and new to my ZL 600 ('87) as well and I'm glad to be part of the fam. I got the bike at a good deal from a mechanic who got it as collateral for a job he did. It's had a few mods here and there but also needs a bit of love (which I am happy to provide!). I've only had the bike for a week so I'm still learning all of the ins and outs. One of the quirks is that the bike only starts in Neutral Without the clutch being pressed. Weird huh? If the clutch is engaged it doesn't even crank, but let it go and it starts just fine. If the bike is in gear and the clutch is engaged, still no action but if I release it then the bike will lurch forward and stall (or maybe if I give it fuel and release the brake it'll take off but I'm not interested in that result so I won't worry too much about it
) So from browsing the forum and other sources I've been assuming that it has something to do with the Clutch switch (which if I disconnect I get no start regardless of clutch or gear position) so it seems to be functioning somewhat.
As a note to this... the bike is running well otherwise however the Neutral indicator in the instrument cluster stays lit even when the bike is in gear. I'm pretty sure this might be related but before I start taking things apart I thought I'd ask for some help and advice!
Thanks Everyone out there and happy riding!
Welcome to the forum. I'm @ 40 miles from you. I'm retired & can look at the bike for you if you would like. You can by pass the switch for trouble-shooting. It may just need cleaned. The neutral indicator being on all the time can be a bad/floating ground. Something else it may have dirt in the contacts at the motor. I have not had one apart on a ZL. The one I am familiar with is there is a small ball bearing inside with a small spring in the motor. When the bike is put in neutral the ball bearing makes contact & turns on the the neutral indicator. It can be stuck & cause it to always stay on. My one duel sport bike had a crack in it were it mounted in the lower end of the side of the motor & the neutral indicator was intermittent. As stated there are quite a few ZL 600 owners that will chime in & tell you for sure what is wrong. A good thing to do with these old bike is go through all the wiring & clean all the connectors. Also before reconnecting them put dielectric grease on the pins inside the connectors.
It will fix problems that you don"t even know you have. I wish I would have done it sooner. It would have saved me a lot of time & money. For example, when I had a high resistance of 27 ohms on one wire going to the large coolant relay. It is amazing what a 50/50 mixture of baking soda & white vinegar will do to the connectors. I learned that from my Dad way back in the late 60s. I'm pretty sure that is what caused all my electrical problems. That & the junction/fuse box. If it wasn't for all the wealth, knowledge & the people on this great forum my ZL 1 would still be dead in the water collecting dust. Thanks to all. R. J.
