Brazle
Hey guys,
I have done quite a bit of searching, but can't find what the carburetor spacing is on the ZL900. I found this thread at concours.org
http://forum.concours.org/index.php?topic=45220
they say: "carb spacing is 77-85-77mm"
Is the ZL900 carb spacing the same as the ZL1000 and the Concours?
I am looking for the best cheap pod filter solution for my '85 and am leaning towards the UNI pod filters. They have 2 options for a 2" inlet.
a) The standard black UNI pod filter which has a 3" OD
b) The Dual Layer pod filter which has a 3 1/2 " OD
I want to make sure the Dual Layers will fit width-wise. So if I go off the 77-85-77mm spacing is that correct?
Also, the black ones are available in 5" length (same as K&N's) and 4" and 6". The red Dual Layer pods are only available in 4" and 6". I'd like to go as big as possible, but since the K&N's are only 5" I don't know if the 6" ones will fit OK or not.
Can anyone with K&N pods tell me if they have another 1" of space for a longer filter pod?
(ref: http://www.unifilter.com/online%20catalog/UNICAT09.PDF)
I like K&N, but it seems they don't filter as many particles as other filters AND the UNI's are quite a bit cheaper ($15 a piece instead of $140 for a set of 4).
Thanks for any info or insight you have.
- Brazle
- Brazle
