ZL900 update into the new century!
PTPopz813 Sep 12, 2018
  1. PTPopz813
    PTPopz813 Member
    59
    I bought a basket case ZL900. Parked for 11 years after a tree branch knocked it over back in 2007. Damage is mostly cosmetic. I have started replacing broken parts already, but am going to update stuff too. Will post photos later this week of what is going on with it!
  2. PTPopz813
    PTPopz813 Member
    59
    Ok now I have time! The tree branch, from what I can tell, hit the left side of the bike. The kick stand got spread out around the frame mount.(loads of play) The left side of the handle bars are 1/2 inch lower then the right side. The speedometer is broken off the triple tree. The clutch master cylinder is broken off the handle bars, the grip is chewed and the choke lever is missing. And lastly there is a dent in the tank on the left side made by the fuel tank lid thing. (What ever that part is called) Like I said, not to bad mostly cosmetic.
    I am the second owner, Dave (the guy I bought it from) gave me the history. He over-revved the bike two months after he bought it, destroying the top end. So he just dropped a motor in it from a wrecked ZL. (Circa Aug 1985) The following spring he installed a lower rise set of handle bars. I totally believe this, since there are rust spots on both sides of the tank where the throttle and choke cable hit on full lock. About a year before the branch hit it the start button popped out of the hand control. When the branch landed on the bike, (plate on the bike was 08/07) he stood the bike back up, it would not even crank. He dug around the wire harness and ignition switch but found nothing. He parked the bike in his garage that summer, I bought it a month ago!
  3. PTPopz813
    PTPopz813 Member
    59
    20180817_155250.jpg 20180716_063952.jpg 20180716_063957.jpg 20180716_064007.jpg 20180817_155207.jpg 20180817_155219.jpg 20180817_155254.jpg 20180817_155132.jpg 20180817_155138.jpg 20180817_155302.jpg 20180817_155250.jpg 20180716_063952.jpg 20180716_064007.jpg 20180716_063957.jpg 20180630_172652.jpg 20180630_172659.jpg 20180630_172722.jpg 20180630_172737.jpg
  4. PTPopz813
    PTPopz813 Member
    59
    Here is the test fit so far. I picked up OEM style bars in black. Need to tank the forks out and rebuild them... They leak. Planning to paint the lower struts, the lower and upper triple and brake parts. 20180817_155219.jpg 20180818_184939.jpg 20180818_183217.jpg 20180818_190754.jpg
    Eastwood likes this.
