Zl900 1985 problem HELP!
Gabmath01 Mar 7, 2020
  1. Gabmath01
    Gabmath01 New Member
    Hi
    My bike is making me out of solutions.
    I have a kawasaki Zl 900 Eliminator 1985. Since I've bought it. I haven't been able to drive it for more than 10 mins before it starts to run terrible.
    I mean; back firing throught carbs and no more power. (This happen right at the same time then that radiator fan starts)
    It still idling perfectly but as soon a touch the throttle it starts lagging.
    If I let it getting back cooler. I can start and ride again for 5 minutes but no more.
    I'm out of solution and I need help!
    I've redone the timing, reajusting valve's clearence at the specs. Went reajusting, and cleaning carbs. New thermostat, coils and spark plug. Even CDi box i replaced.
    Everything is installed perfectly.
    I even tried to unplug the fan in case of an electrical problem but samething happen.
    When I let it sitting idling, as soon as it gets working temperature. It cannot runs.
    Help please! So I can finally get it fixed!!
    352
    Coil pickups could be going out on ya. Check cdi connection for corrosion as well as the fuse box plugs.
  3. GaryD
    GaryD Supporting Member
    443
    43
    Not saying this is it but I once rebuilt a Z1100 engine and it had the same symptoms as yours. Took me months to discover the advance mechanism was wrong for the bike.!!! hence the overheating...
    Once swapped with the proper one it ran perfectly.
  4. furchin
    2,173
    95
    I would lean toward a vacuum issue. Try opening the gas cap, leave it open and see if the bike runs better.
  5. Gabmath01
    GarryD w
    hat was the problem?
  6. wuputt
    3,182
    47
    I agree with Furchin.
  7. GaryD
    443
    43
    My problem...at the time was that it would start but quickly overheat and run like teh fuel was bad.
    Obviously it was because the timing was wrong...would happily ilde but once the advancer kicked in it ran like a dog.
    So maybe look at the timing to se if it's breaking down when it gets warm.
  8. 87kawzl
    352
    The timing plate is fixed on the ZL and electronically controlled thru the CDI.
    The keyed ignition switches have had issue and needed cleaned on these bikes before. Try to wiggle the key a hair to a different position when it acts up and see if that makes a difference.
  9. Gabmath01
    How to test timing when hot?
  10. lowlife
    3,499
    Let's not forget to check fuel delivery as well as what's posted above. Might be just enough to keep the carbs filling but not enough to keep them full after a few minutes. I would check with what's posted above first.
