ZL400 cylinder head removal
DONALD PENDER Jul 7, 2019
  1. DONALD PENDER
    DONALD PENDER New Member
    Hi Gentlemen and Ladies. I was given a ZL400A in not so good cond. but will get around to
    sorting it. Frame No ZL400A 006202 not sure what year that is, but is it possible to remove cylinder head in
    with engine still in the frame? I thought I'd ask first.
    Don
  2. Trojan441
    449
    30
    I have never had to lift one off, but I think it is a job with the engine in the frame.
    The tricky fiddly bit is the cam cover which you remove from the left side of the bike n' replace from the right side when rebuilding , but to do the job U need the bike more upright than the side-stand facilitates!
    Drain coolant from the small bolt @ the water pump;
    Remove the fuel tank;
    HT Leads;
    Remove Knee pad protectors.
    Remove the top coolant hoses from the fixings n' take off the Coolant pipe stubs unbolt the Cam cover 6 bolts n' wriggle it out to the left side, here wiring n' cables can make it tricky.
    Watch U don't loose the four oil pipe Rubber/Neoprene caps, especially down the central cam chain tunnel, when rebuilding put a little grease on the Neoprene caps to hold them in place!
    Go to the Motorcycle Manual section n' print off the ZL 600 stuff, the bikes are essentially the same, Where R U based?
  3. Trojan441
    449
    30
  4. Trojan441
    449
    30
    Oh! n' on the fuel side the carburettor rack n' associated cables, Air-box e.t.c. On other ZX 400 n' ZX 600 models I believe, (according to the manual), that the cylinder head could be removed with the engine in situation in the frame.
  5. DONALD PENDER
    thanks for that info. I'm Aussie living in the Philippines for past 12 years. I have 14 or 15 other bikes and didnt
    really want this one but my friend offered it to me for free. He believed it was loosing compression between cylinders
    Time will tell.
  6. Trojan441
    449
    30
    Lucky Guy, even old knackered shite bikes are commanding premium prices, if they can get away with it in the UK?
  7. 87kawzl
    149
    Did you try a valve adjustment? What makes you feel that the head needs removed?
  8. DONALD PENDER
    thats all I got from the previous owner. when I picked it up a few days ago . the spark plugs were out of it
    and I'd say they have been out for a few years and for all I know its got rain water in the cylinders.
  9. Trojan441
    449
    30
    I hope the damage is light n' repairable without to much hassle!
  10. DONALD PENDER
    well if the bores are not rusted then maybe a hone and a set of rings etc
    399
    :hello: You might find a tough time finding a set of rings. I'm not even sure that you can get pistons from KAWASAKI.
  12. Trojan441
    449
    30
    U can get ring from Japan, "Crusin Image on Ebay, but he doesn't state where they R made, rings cost from £120- £200, U can get rings from China I think, but an article in a English Vintage Japanese Motorcycle Mag' said some of the suppliers stuff U could flex n' bend! Any ZX 400 1986 -1993 56 mm pistons should fit the ZL 400, Annoyingly the Japanese supply every individual part separately, circlips, rings, Gudgeon pins, piston (x 4)!
  13. DONALD PENDER
    I think all the ZX400's are 57mm bore
  14. Trojan441
    449
    30
    Kawasaki did a 1mm Bore increase piston for the ZL, but I may be wrong but I think in the Spec sites such as https://www.motorcyclespecs.co.za/model/kawasaki/kawasaki_zx4F3 88.htm some of the information is incorrect! Why would Kawasaki vary bore n' stroke on a 400cc's compatible engines? I have a ZX 400 but as yet haven't stripped down yet to measure piston size! But if the bore is bigger then just fit ZX 400 barrels n' pistons.
  15. DONALD PENDER
    my research shows that only the ZL had a 56mm bore, all the other 400's ,GPZ, ZX etc had 57mm bore.
    Well the valve clearances were ok on mine but now waiting for a long series 12mm socket to remove head and
    investigate. Also The ZL has its own engine coz the gaskets (head and base) are different from the other 400's
    The cylinders and head are different.
