ZL 600 Eliminator Spark Problem Please Help
Gakomi Apr 6, 2018
  1. Gakomi
    Gakomi New Member
    I fell with the bike and after that it never started again ! I check to see what the problem was and it seems it only gets spark on plug 1/cylinder 1, I check to see if the plugs where the problem and they are not. Can anyone tell me what could have failed ?
    7,890
    304
    :hello: I'd start with new spark plug wires. Did you check the wire connections at the 2 coils under the seat.
  3. furchin
    2,073
    47
    Two things I would check, The starter relay (under left side cover) and the kick stank switch to see if any wires may be loose or broken.
  4. Gakomi
    Gakomi New Member
    Already checked that and it was not it ! I found out what it was, I had a brocken wire that was going to one of the igniton pick up pulser or whatever that thing is called !
  5. Gakomi
    Gakomi New Member
    7,890
    304
    :hello: Good deal!! :clapping:. Glad it was just a broken wire. Was it one of these. IMG_6100.JPG
  7. Gakomi
    Gakomi New Member
    yes it was one of the wires that come form the 59026 it was cut by the 92037 thingy !
    7,890
    304
    :hello: Was one of the pulsing coils clamps cutting into the harness.
  9. Graphixman
    Graphixman Member
    I might have same issue on the 900 mine lost spark and starting problems..
