ZL 1400 shaftdrive?
MachIV Oct 3, 2018
  1. MachIV
    MachIV Senior Member
    I may have a wrecked Connie 14 coming in.
    It's been rear ended...I've still got some Mean Streak stuff left, wheels,swingarm,gauges etc.
    Also some ZX14 bits here and there.
    Gonna test fit some stuff and see.
    No promises.....
    wuputt likes this.
  2. markus56
    3,245
    148
    There have been several started but never taken that far yet.......would be cool to see somebody take this goal to fruition. Great to see you post again!
    7,910
    308
    :hello: After I'm done with all my projects I'm going to put a 14 connie motor in a 2015 Valcan.
  4. GaryD
    GaryD Supporting Member
    313
    It's a project that's deffo on my list ...just need to move on a few bikes and put the ZL1100 back together....restore the Zl1000.
    Hm,mmm don't hold your breath. But I do have a tank that I'm going to get a fibreglass mould from.
    Biggest headach that I foresee is streatching the s/arm & prop to get the right 'look'
  5. Harriminator
    774
    141
    ZL1000+ZL400=ZL1400...???:whistling::D
  6. GaryD
    313
    But then it would have 4 wheels...which makes it a car!
  7. Harriminator
    774
    141
  8. GaryD
    313
    Jury is still out on that...love all the innovated stuff Yamaha have done.
    Just looks a little 'over engineered'
    Worth buying one as a future classic but not sure I'll need it or the money when i'm in my eighties.:D
  9. GaryD
    313
    Not good at the photoshop thingy. So this is the best I can come up with to see how things would fit. ZL1400 merge.png
  10. GaryD
    313
    You can see the engine is a lot further forward. So if shoehorned into a ZL frame it should puch the rear wheel further back into the 'right' position.
  11. MachIV
    Gonna use the Connie frame, well the front part anyway.
    "Tank" will probably just be a hollowed Vulcan tank as a cover.
    This will be more like the ZL Kaw should have built.
    markus56 likes this.
  12. GaryD
    313
    There's an idea, connie frames are dirt cheap.
  13. markus56
    3,245
    148
    Mach, do you mean the 1400 Connie or the old C-10?
  14. GaryD
    313
    Good point.
    I'll be using the 1400 frame as it solves a lot of problems.
  15. MachIV
    1400 frame and probably Mean Streak rear tail frame with Marauder tail.
    For those that don't know the Marauder was a rebadged Mean Streak with a different tail/ tail light.
  16. MachIV
    And what happened to my avatar pic?
