zl 1000 oil coming out of exhaust
zl 1000 Apr 3, 2019
  1. zl 1000
    zl 1000 Member
    zl 1000 oil coming out of exhaust . Is there a com problem for this .?
    140
    Overfull crankcase?
    Dripping or smoke?
  3. wuputt
    3,074
    12
    123
    I have never heard of this problem! Definitly want to check the oil level, make sure theres no gas or coolant in it. Is it smoking the blues? Are you sure its not dirty condensation?
    Let us know what you find!
  4. Jukka Hakala
    Jukka Hakala New Member
    My exhaust smoke is getting blueish when I accelerate heavily. My friend said it might be because valve gaskets are leaking? Might this be the case? Also plugs are guite black. Any similar kind of experiences anyone?
  5. Harriminator
    810
    161
    Blue smoke = engine burns oil; suggest a step-by-step check list like this:
    1. oil level check
    2. compression test to check piston rings
    3. head gasket check (water in oil or coolant black colored?)
    4. valve stem seals to be replaced
    Keep us informed :thumbsup:
    381
    :hello: Have someone ride closely behind you slowly then speed up. Do this several times & have them smell for burning oil.
  7. paulfun
    4,055
    49
    Broken or stuck ring is most likely to cause enough oil to get in that it can get out the exhaust without burning.
    Excessive valve guide wear in most cases will cause oil burning but not actual oil coming out the exhaust unless the crank case vents are blocked or capped for some reason
  8. Ed
    Ed Active Member
    194
    In general:
    Smokes when throttle closed = leaky valve seals
    Smokes when throttle not closed = leaky rings
  9. Trojan441
    397
    27
    This problem should be sorted quickly, what mileage has your machine done? If a piston ring breaks could b a rebore job, new rings or more expesively new pistons! Blue smoke is I think we are all agreed burning oil. Replacing valve guides may be a specialist job too. Best scenario maybe is gummed up piston rings stuck up or worn rings exhibiting a fluttering motion n' letting oil blow by past them!
  10. Ed
    Ed Active Member
    194
    If it's liquid oil coming out, it's probably a bad head gasket.
  11. 87kawzl
    140
    You sure the water pump isn't going bad and leaking oil onto the exhaust? That is a common occurrence as these bikes age.
