What type of engine oil?
zl_havoc Dec 22, 2012
  1. zl_havoc
    zl_havoc Well-Known Member
    148
    53
    What type/brand of engine oil do you guys find the best for our zl900's? Some where I read synthetic wasn't good for our engines. I'm doing my first oil change on it and want to use the right stuff. Thanks.
  2. gosupes
    gosupes Senior Member Supporting Member
    The ZL900 and ZL1K's use a different starter clutch, the 1K being the better setup. Some people have had issues with the starter clutch acting up on their 900's after using synthetic. Most are happy with MC specific oil or something like Shell Rotella. Just don't use any type of oil branded as "fuel saving" or having friction modifiers as it will not work well with wet clutches. I personally like the Rotella 15-40. You can get it al wally world for cheap and it works well with the moderate temps around here. I only put on about 3K miles a year. If I rode more or under hotter conditions, I would probably go with the Rotella synthetic. This has been discussed on the forum many, many times. Do a search and you should find plenty of good reading material.
  3. zl_havoc
    148
    53
    Thanks for the info. I was looking at the rotella but wasnt sure. Something like the Rotella diesel blend.
  4. f1nxlife
    f1nxlife Supporting Member
    1,145
    I use Golden Spectro 4 10-40 Petroleum base oil in the 900, I use Golden Spectro 4 semi synthetic 10-40 oil in the 1000 and I use golden spectro semi synthetic 20-50 in my Ninja 1000R and in my Hyabusa.Im having great results with both my ZL s using the oil I have described, you should do the same..
  5. zl_havoc
    148
    53
    Where would I get golden spectro at? Never heard of it.
  6. kawboy
    Cycle shop or online retailer like dennis kirk or chaparral
  7. rkerg
    rkerg Senior Member
    I have been using Rotella 15-40 in my 900 since 08 & am very happy with it.
  8. madmanncr500
    5,362
    36
    +1 on the Rotella 15-40...:thumbsup:
  9. Scoobys_piece
    2,026
    me 2
  10. zl_havoc
    148
    53
    I went to wally world and for less than $14 ill go with the rotella. Although for $22 Kawasaki has their brand oil, anyone tried that?
  11. Jarney
    4,475
    12
    I think many like myself used to use the Kawasaki 20w50, ran it a long time with no problems but after hearing all the good reviews on other oils, I wound up switching to the Rotella like most have and would never go back to Kaw brand now. Rotella is easier for me to obtain, cheaper, seems better for the bike all around - quieter, easier cold starts, etc. Your results may vary, but that's what I noticed about it. And like others have stated, I would not bother with the synthetic on the 900 due to the starter clutch issue that some bikes seem to may or may not have. Later.
  12. reddobie0
    reddobie0 Well-Known Member
    425
    Rotella 15w-40 in all my bikes. New bike I bought guy gave me 5 quarts of Amsoil Motorcycle oil 20w-50. Will sell in the spring too heavy for me.
  13. AlanC
    AlanC Member
    84
    Went to Walmart to pick up some Rotella 15w-40 for my ZL900; many here seem happy with that brand. However, it said it was Heavy Duty Diesel oil. Is this the same Rotella 15w-40 that all of you are using or is there another one that is not for diesel motors?
    Thanks,
    Alan
  14. kawboy
    Yes, it's diesel oil.
  15. AlanC
    AlanC Member
    84
    Thank you Kawboy.
  16. prfixer
    1,389
    45
    But that is the Rotella that everybody is using, even though it is labeled for diesel.
  17. Scoobys_piece
    2,026
    We use this oil, because we are "mimicking" a diesel engine. Diesels are built really HD, due to high compression and other propertys that we benefit in using this type of oil. It has a higher "sheer" point. I really like the way it behaves in the "two finger" test. Basically get some different viscositys of oil you have laying around. Then place a very small amount (about the size of a ballpoint pen tip) yea...that small. between your fingers and rub them together....I learn this from an old guy...really old guy..long story, but anyway. you'll notice the Rotella in particular having a much higher "cling" and resistance to dissipate. Whereas, synthetics will get outta the way quicker that you can shake a stick. Then regular oil is between the 2.
  18. jd2ndzl
    jd2ndzl New Member
    15
    Is that the rotella T 15w 40
  19. rkerg
    rkerg Senior Member
    Yes.
  20. RLTherio
    RLTherio Well-Known Member
    323
    27
    Has anyone tried Castrol's 4T synthetic oil?
