What the heck?
PTPopz813 Sep 12, 2018
  1. PTPopz813
    PTPopz813 Member
    59
  2. MikeC
    MikeC Senior Member
    452
    103
    20180912_192848.jpg If you look just in front of the foot peg directly underneath, it mounts to the oil pan. Unless im mistaken. I forget what it is.
  3. MikeC
    MikeC Senior Member
    452
    103
    How does the fuel tank look inside. Full of gas for ten years or empty?
  4. 87kawzl
    87kawzl Senior Member
    1,382
    91
    Oil sensor off the oil pan
  5. PTPopz813
    PTPopz813 Member
    59
    I have not looked yet... Have to punch the lock, the PO lost the keys. Feels like about half a tank.
  6. Harriminator
    751
    127
    Cable color BL/R => oil pressure switch.
    7,805
    289
    :hello: I wouldn't punch out the lock. It is very hard to find replacements. You can remove the ignition & take it to a lock smith & he can cut you a new key. It costs about $50.
  8. PTPopz813
    PTPopz813 Member
    59
    I already have a complete lock set, the original Ignition switch was destroyed by the original owner. the only lock I have not replaced so far is the seat lock and the fuel tank lock.
  9. 87kawzl
    1,382
    91
    A small nut holds the wire on the sending unit stud.
  10. PTPopz813
    PTPopz813 Member
    59
    metric I bet
  11. PTPopz813
    PTPopz813 Member
    59
    Mine is a small bolt that screws into the sensor. I am going to have to repair the wire... it has been sitting against the exhaust and is melted.
