  1. Not a V-Max
    Not a V-Max New Member
    13
    Looking for a pair of Supertrapps. I had a perfect pair that I sold on an ‘85 ZL900 back in 2003, never thinking I would ever buy another Eliminator. And then 16 years later I did. They don’t have to be perfect. A wrecked pair or single may work. I more or less need them for measurements to TIG weld and fabricate a new pair from donors. I contacted Dale Walker and he told me what he could. I talked to him once before back in ‘95, he’s a good dude. Don’t hesitate to buy from him. He also told me that once his warehouse stock of Hole Shot slip-ons is exhausted, they will no longer be available as well.
    127
    https://www.summitracing.com/parts/sup-443-2017/ look close but the cone on the ZL is eccentric. RJ mounted a shorty trapp if that look fits the bill with you it allows more room for a mid pipe.
    I can hook you up with measurements from originals if you could use them.
  3. Not a V-Max
    13
    Any measurements and pictures would be greatly appreciated. If memory serves me correctly, they were 3 inch megaphone trapps that we’re cut and modified with stainless steel funnels. It was all TIG welded together to hook directly in the stock head pipes with the resonator removed.
    343
  5. Not a V-Max
    13
    I checked out your 10" trapps. They give a nice clean look. I can't tell for sure, but it looks like you kept your resonator(pre muffler). Does keeping that on choke up your exhaust at all?
    343
    :hello: Yes the cross over resonator is still part of the exhaust. I kept it because the SS pipes that Willy D made was designed for the resonator.
  7. Not a V-Max
    13
    Measurements would be great thanks.
  8. 87kawzl
    127
    I need to round up my angle finder, it's at my other house.
  9. 87kawzl
    127
    I didn't forget about you. It's going to be tough to get the proper angles of the pipes without taking one off. Even then there are some funky angles involved. It definitely wouldn't be an ez cone to make for the transition from header to the muffler. I've been really busy with getting a house ready to sell but will find some time sooner or later.
