Starter clutch
BearHunter Apr 9, 2018
  1. BearHunter
    BearHunter Member
    37
    I’m reading me and obviously I’m not very clear. Synthetic oil was in the bike since I got it last summer. I changed oil saturday for Rotella and starter slipped on monday morning. Can it be related? I mean Rotella is for sure thicker at cold temp than synthetic stuff?
    87kawzl Well-Known Member
    1,077
    49
    93
    I always use motorcycle specific semi synthetic, the oil companies add additives for wet clutch and trans gears. What weight did you use? 10-40 should flow good cold rotella or otherwise. I'd change it out, sounds much cheaper than opening it up.
  3. BearHunter
    BearHunter Member
    37
    Rotella T4 is 15w40.
  4. 87kawzl
    1,077
    49
    93
    I'd do a fluid change and leave the filter then see how it runs.
    7,195
    194
    108
    :hello: Hard to say. At this point most likely sooner than later it will need replaced. I've been told once you go to full syn oil that you shouldn't go back to conventional oil.
  6. 87kawzl
    1,077
    49
    93
    Straight from Pennzoil:
    "Myth: Once you switch to synthetic oil, you can never switch back. This is one of the most persistent myths aboutsynthetic oil—and completely untrue. You can switch back and forth at any time. In fact, synthetic blends are simply a mixture of synthetic andconventional oils."
  7. BearHunter
    BearHunter Member
    37
    I just give a call to a local Kawasaki dealer. The oneway clutch assembly part number 13193-1052 is discontinued... :icon_scratch:
  8. BearHunter
    BearHunter Member
    37
    What should I do?
    Buy a rebuild kit available from various source for about 50$?
    Buy a starter clutch of another model? I think the model from the ZL1000 is also discontinued. Do you know of any other part number than can ben a drop in?
  9. 87kawzl
    1,077
    49
    93
    Try a quick oil change and see if the symptoms persist since it started with your oil change.
  10. BearHunter
    BearHunter Member
    37
    Yesss oïl change is planned for the next monday. I'll go back to synthetic.
  11. RLTherio
    RLTherio Active Member
    267
    13
    If an oil change still doesn't fix the problem, the internal parts are still available for rebuilding; pins, springs and rollers.
  12. BearHunter
    BearHunter Member
    37
    Yes I've seen. I'll probably order a kit and do it during 2 days of contunuous rain during my summer vacancies... ;)
    7,195
    194
    108
    :hello: Go to page 2 of this post. Everything that you need to know is explained. Do not buy a rebuild kit until you inspect the outer housing of the stater clutch for cracks.
  14. BearHunter
    BearHunter Member
    37
    Yes, I've seen that also!
  15. BearHunter
    BearHunter Member
    37
    I did an oïl and filter change this morning. I went back to full synthetic 10W40. I took a ride to settle it and now everything is going just fine. There's absolutely no delay or hesitation. A push the start button and the starter makes the engine running.
    I kept the almost new Rotella, it'll go in the lawnmower...
  16. 87kawzl
    1,077
    49
    93
    Your trans gears will thank you too. Hope you have no more issues with it!
    7,195
    194
    108
    :hello: Did you use motorcycle grade oil. Most automotive oils have properties that over time will deteriorate a bikes clutch fiber plates.
  18. BearHunter
    BearHunter Member
    37
    Yes, I used a brand called Liqui Moly in 10W40 grade. It's meets JASO MA2 spécifications. The starter clutch obvioulsy have a problem because it don't works properly with mineral oïl. But instead of a 2 days rush summer repair, I'll do it during the winter... ;)
