Splitting the crankcase/replacing bent connecting rods.
The Original Sin Apr 19, 2019
  1. The Original Sin
    236
    24
    Hi y’all, I’m looking to chat with someone who has split the crankcase on a Zl1000 and has replaced the crankshaft and or replaced bent connecting rods.
  2. furchin
    2,172
    95
    Do you know which rod'(s) are bent? If I remember correctly if #2 or #3 is bent you do not necessarily have to split the cases. You can pull them from the oil pan side underneath. If #1 or #4 are bent then splitting the cases is required.
  3. The Original Sin
    236
    24
    Number 4. I thought about that....
    Have you ever done this scope of work?
  4. furchin
    2,172
    95
    You will have to split the cases seeing that it is #4 rod. No, I have not personally done this but have had it done to my 1000 engine after suffering from a hydro lock. Our founder ZlMark (rip) did the work for me.
  5. The Original Sin
    236
    24
    I think I’ll just replace the engine and save the detail engine work for a cold winter’s day. Riding season is here!!!
    rkerg and R. J. like this.
