Seventh Gear (Connie 1000 Bevel Gear drive)
Ducky Dog Apr 11, 2018
  1. Harriminator
    584
    84
    113
    :hello:It was a construction fault, we should urge Kawi for a recall...only 30 years ago.:rotf:
  2. Ducky Dog
    Ducky Dog Active Member
    110
    11
    I am really surprised more folks havnt converted their out drives to this setup
  3. RLTherio
    RLTherio Active Member
    267
    13
  4. Harriminator
    584
    84
    113
    7,195
    194
    108
    :hello: :Laughing4:.
  6. prfixer
    1,277
    23
    You should probably just go ahead and buy a Concours, that high gearing would kill what we love the ZL's for!
  7. Ducky Dog
    110
    11
    I had called that guy and he told me to buy the connie outdrive as it would get it up Approx 8% from stock zl9
    and save me some money
    7,195
    194
    108
    :hello: Did shouldofbeenengineering say what they do to the connie bevel gear to gain 12% higher gearing. $500 is steep.
  9. RLTherio
    267
    13
    I will have to guess that he changed the bevel gears. I tried to find out what the teeth count was but to no avail.
  10. Ducky Dog
    110
    11
    All is well so far with the connie out drive with one exception,,,,,
    the water pump o ring I got from partzilla seems to be seeping oil (dam it)
    I figure they are not clued in on the proper thickness of the o ring
    I have a set of metric o rings so I will pull the water pump and see if I have a thicker one that will work
    anyone have this happen to them?
    7,195
    194
    108
    :hello: Did you wipe off any oil that might of been on the hole as to were the water pump goes into the motor.
  12. Ducky Dog
    110
    11
    Hi RJ
    Yes the whole area was cleaned
    installed bevel gear housing
    installed waterpump with new "oiled " oring
    water pipe and hose
    clutch pusher ,,,,, etc
    I realy think I got an undersized oring,,, It had a oil leak in the same spot before I did the work but it was very minor , never hit the floor
    now it is much more
    I will look into it tomorrow AM
  13. Ducky Dog
    110
    11
    well I was so intent on checking into it I tore into it this afternoon
    I found the o ring was correct and sealed good but I found the inner seal at the shaft was out of place. It looked un damaged but it didnt want to stay in place (it kept slipping out) so I cleaned it with carb cleaner pushed it in half way then I ran a bead of super glue around it and pushed it in the rest of the way,,,,, presto! (got to love that super glue)
    reassembled everything and so far no drips
    tomorrow I will take her out and shake her down
    7,195
    194
    108
    :hello: I use ultra black gasket maker when I put the oil seal in a water pump. In pic the seal is in upside down. The spring side of the oil seal faces in. IMG_6120.JPG
    Ducky Dog and markus56 like this.
  15. Ducky Dog
    110
    11
    Thank you brother
    7,195
    194
    108
    :hello: No problem. I'm glad to help out. :notworthy:.
  17. Ducky Dog
    110
    11
    50 miles and no leak
    all better
  18. R. J.
    7,195
    194
    108
    :hello: Good deal. :notworthy:. The next time do not use super glue it looses it's tensile strength under heat & dries up.
  19. Ducky Dog
    110
    11
    But it was guerrilla super glue:headbang:
    LOL
  20. R. J.
    7,195
    194
    108
    :hello: But it's not garolla super gasket maker. :laughing7:.
