Replacing Ignition Switch
genefrost_zl900 Jun 17, 2015
  1. genefrost_zl900
    genefrost_zl900 Active Member
    19
    So my oldest boy seems to have lost my keys to my 85 ZL900. I got a new ignition switch off ebay that showed up yesterday but wondering if anyone on the forum has any tips or suggestions on how to replace. I obviously can't get my seat open either... The plan is to take my ignition switch to a Locksmith once it's off the bike so I can get keys made and put it back on the bike but for now I need to get it off and use the new switch in the mean time.
    Any help is greatly appreciated.
    Thanks,
    Gene
  2. prfixer
    1,313
    35
    Remove the headlamp, unplug the switch inside the bucket(and probably the other connections as well), remove or move out of the way the headlight bucket, and the switch is held from the bottom by 2 allen bolts. You also have to remove the ignition switch cover which is held on by 2 phillips screws from underneath.
  3. madmanncr500
    5,362
    34
    If you take your old ign switch to a lock smith they can make you a new set and then it will be like you never lost them......I know I lost mine.....:banghead:
  4. genefrost_zl900
    19
    And to remove the headlamp you unscrew the two bottom phillips screws on the bottom of the headlamp bucket? Is that correct... yes I've had the bike since 92 and never had to replace it... knock on wood.
    Thanks guys!
  5. wideguy
    wideguy Member
    13
    Gene, I've removed a few ignition switches. Every one was intentionally somewhat difficult to remove, and all needed at least one tool you probably don't have.
    Locksmiths will come to you, which may be cheaper in the long run unless you've some mechanical skill.
    The headlight bucket is completely in the way. When you dismount it, try to just move it out of the way, because putting the wires back correctly can be tricky, and is always a PITA.
    I can't imagine not having a spare set of keys... What are you going to do with the unit you bought on e-bay?
    7,446
    241
    108
    :hello: You can trailer/truck your bike to a lock smith & they will cut a new key. I have 7 keys for my ZL. :laughing7:
  7. kawboy
    ^^^ did you trailer it 7 times?
  8. madmanncr500
    5,362
    34
    :yeahthat::rotf::rotf::rotf::rotf: Poor RJ :laughing7: WERE ARE MY KEYS....camera ,,,,sunglasses .....phone......were did I park my bike:pk:
    7,446
    241
    108
    :hello: I have never lost a set of bike keys. One time I lost a set of keys to a sport quad I was working on. I spent $45 to have a key made for it & 3 months later I found the ones I lost in my wife's crock pot. :laughing7:
    7,446
    241
    108
    :hello: I removed my ignition switch from my ZL 10 to take it apart for cleaning. When I tried to open it up one of the slots/tabs on the plastic housing cracked so I just sprayed brake parts cleaner in the small holes & checked it for loose/broken wires. It makes a sold contact in all positions. My problem is when turning the key to the on position some times I need to turn it counter clockwise just a hair in order to get power to the bike. Again I have no play or weakmess in all the positions. Also now the back side black cover does not snap on as tight as before so I put a piece of black electrical tape on it to hold it in place until I slid it under the stay tab on the medel housing. So how do I go about taking it apart with out screwing up the plastic housing. IMG_5496.JPG
  11. 87kawzl
    87kawzl Well-Known Member
    1,220
    62
    93
    All of the crud builds up on the contact side of that plastic piece that you cracked. contact cleaner won't fix it for ya. I use a brass brush to clean things like that up. If I remember correctly there are springs and balls that can get lost easily, take it all apart and clean thoroughly. Put a very light coat of dielectric grease on the contacts and button it back up. I really like gorilla glue, in this case I'd use the gorilla super glue you may want to glue the plastic to aluminum if it's real buggered up.
  12. markus56
    3,044
    106
    Yeah, those things take a bit of finese to get apart without breaking. I agree with the above post and glue it together when you go back with it. The next time you have to take it apart, you can have a good one from an old switch ready to replace it with. Kaw don't sell them without the switch.
    7,446
    241
    108
    :hello: So what you are saying is just break it open. How do I go about without breaking it.
  14. 87kawzl
    1,220
    62
    93
    There's tabs but it takes a gentle hand to pop it without damaging the plastic.
  15. markus56
    3,044
    106
    Yep, GENTLE persuasion!
    7,446
    241
    108
    :hello: Does anyone have one for sale.
  17. markus56
    3,044
    106
    Keep an eye on E-Bay, they do come up once in a while. I'll check my stash for an extra one and get back with you.
  18. R. J.
    7,446
    241
    108
    :hello: Thank's: :notworthy:. I don't need the top section that the key goes into just the plastic section.
  19. markus56
    3,044
    106
    I have the switch out of my last parts bike dug out and ready to send you R.J. The plastic switch on the bottom looks good but I'm sending you the whole switch so you can take it apart. Send me your info and I'll get it headed your way. Thanks for all you do for us here Brother! Just pay shipping and it's yours'......can't beat that!
    R. J. and kvalheim like this.
  20. R. J.
    7,446
    241
    108
    :hello: Markus thank's a million. I'll need your paypal info.
