Questions for Dale Walker
Guest Aug 17, 2007
Tags:
  1. Guest
    Guest Guest
    ZL 900 For Sale
    1985 Eliminator for sale. This bike is stock except for K/N air filter and Progressive springs. Carbs have been ultrasonic cleaned and synched, and valves recently adjusted. Always adult owned and garage kept. 39k miles,asking 2900.00 or would consider trade,, ZRX1100,1200 or CB1000. THANKS Kevin
  2. ARCHIVE_Wuputt
    ARCHIVE_Wuputt Guest
    Kevin,
    Welcome to KERA! Where are you located? Got any Pics? You need lots of pics with close detail. Also need a much more detailed description of any defects. How many owners n stuff.
  3. Guest
    Guest Guest
    Wuputt, I am located in far western KY. This bike was a one owner until about three months ago.. It was stored for about 2 years until I bought it from the original owner.. I also rebuilt the calipers, both brake masters, and it has a new battery.. I will post pics as soon as I figure out how. THANKS
  4. ARCHIVE_Wuputt
    Hey Kevin, I think the only way you can post pics on this site is to have a photoshop acct. you can then copy the url in the forum herelike this
    copy url here
    Come over to zl-oa site, you can become a member, we have a active gallery there.
    Here is the link, look forward to seeing you there!
    http://www.zl-oa.com/index.php
  5. ARCHIVE_zlMark
    ARCHIVE_zlMark Guest
  6. zl900_moab
    zl900_moab Senior Member
    This is the spot to post up your queries for Dale....Now let's keep in mind that he is doing us a favor by being here, and not all pile on at once...Let's post up a few and see where that takes us, as he will not be on every day.
    Behave yourselves.
    Thanks Dale for your time!!!
    moab...
  7. DaleWalker
    DaleWalker Eliminator Legend
    81
    Dale says Hello
    Your welcome and good idea about this thread moab
    Im getting a few things togehter for you at this time, but really gots to dig
    Its been whlie ....... he he
    I will check back in here
    Cheers Dale :happy1:
  8. zlMark
    zlMark Cult Leader
    8,935
    227
    121
    Great Idea!
    Welcome Dale!(again!)
    Glad to see you made it in here. I'm really exited to have you here. Let's get this thread rolling!
    I wanted to talk about slide drilling. I don't know if your kit requires this and what are the advantages?
  9. vinny
    vinny Senior Member
    Welcome Dale :D
    Reading Andrew's report back from your discussion, just thought -
    as the ZL motor appears to be prone to heat issues - would fitting an OIL COOLER be a good solution ?
    I know Dale recommends Engine Ice , but would appreciate his thoughts on this.
    Vin
  10. lowlife
    lowlife ZL Mad Scientist Technical Author Supporting Member
    3,409
    Hey alottery system for asking questions would be a good idea...Well lookie there I drew # 3, guess that means I get the next question :D
  11. vinny
    vinny Senior Member
    Hey Mark / MOAB,
    we can't have Dale Walker with TRAINING WHEELS ! :nonono:
    Maybe ANTI-WHEELIE BARS or GOD would better suit his ranking !
    :dancingfool:
  12. zlMark
    zlMark Cult Leader
    8,935
    227
    121
    Good point vinny. maybe we can hook him up with a moped to get around :rotf:
    Holeshot fits him good :D
  13. DaleWalker
    81
    Hello guys , just doing a few e mails and checking back in
    ZL Mark wrote :
    Great Idea!
    Welcome Dale! (again!)
    DW: Thanks Mark
    No i dont drill the slides in my kits ,The slide springs and original needle taper is actually very good in the ZL carbs, with the right jetting along with shimming the needles properly they work fine without drilling. The bikes are so low gear they snap right to life anyway and i dont like to drill anything internally if i dont have to. With more air flow, my + 4 advancer and a good A/F ratio they come alive pretty well. Also very smooth through the rpm range.
    Vinny wrote:
    Welcome Dale
    DW: Hi Vin
    The ZL was much better than the first couple years of the 900 Ninja. I would say run a good synthetic oil, a 9 heat range spark plug with the engine ice and that should be fine. Being that the motor is open and the radiator is a pretty good size there ok. With engine ice added , if the fan still kicks on a lot Id maybe add a switch to turn it on a bit sooner. But try the above first.
    They are also very lean from the factory so one my jetting kit helps get the heat out of the cylinder head as well.
    As far as oil, i dont want to start a oil thread, because they can go on until the end of time......ha ha .
    I run and really like Synthetic Rotella T 5w-40 sold at Wallmart , for about $4.40 per qt.
    Ok guys got to do my 100 e mails now so take care and i will check back in a few days.
    Cheers Dale
    :cool10:
  14. lowlife
    3,409
    Dale, I'm looking to get a little more power, not asking for alot. I want to keep it stock appearing (exhaust etc) and my carbs run very crisp and i can get over 40 MPG when I drive it right and I kinda like that. I guess I AM asking alot. Don't wanna mess with the carbs or exhaust but yet I want more power, I WANT IT ALL!!! God I sound like my wife. Thanks for your patience Dale :D
  15. acp
    acp Senior Member
    992
    Quick one for you Dale.
    I'm looking at getting pods and dynojetting my carbs, as I've had to get a new exhaust system.
    Is it necessary to put an advancer in the bike as well, like the one you sell for it? Or is the advancer another optional add-on?
  16. DaleWalker
    81
    Dale ?
    Hi Lowlife
    Well cant have that cake unless you do some work really.
    The stock mufflers as well as air filter and air box are pretty restrictive. Id at least go with my stage 1 jetting kit even if you want to keep the original mufflers on it.
    There is a few hp in the air flow and proper tune up for sure. Keep in mind my stage 1 kit also comes with my timing advancer and those motors like that.
    Cheers Dale
  17. DaleWalker
    81
    Dale ?
    Hi Acp
    If you have yet to buy the kit, you should consider my stage 2 kit instead. Its simpler to set up comes with the pods, crank vent filter and my advancer is included.
    It will work fine with any after market pipe
    I can also help you fine tune it after you install it which means a lot these days.
    Now then if you have already purchaced the other kit, yes i would buy my advancer and install it also.
    It really helps the throttle response.
    The other thing i forgot to mention to Lowlife also is the Dyna coils and wires, that wakes them up also. The originals are marginal even new and now are getting very old.
    Cheers Dale
  18. CHRIS
    4,659
    20
    HEY DALE,
    is it possible to buy just the timing advancer ? if so, how much, & what are the advantages of having one on a stock zl 900 ? thanks, CHRIS
  19. vinny
    vinny Senior Member
    A couple of questions for Dale - if he doesn't mind. :D
    1) How much time does the electric shifter save on a run at the strip?
    and
    2) I have read - elsewhere, that having a bit of polishing done in the cylinder head can help tp reduse heat there. Is that true? :detective:
    Thanks in advance Dale. :D
  20. tmdoth
    tmdoth Senior Member Supporting Member
    dents in exhaust
    Hi there Dale, had a quick question for you. Took off the exhaust in the process of getting to the top end of the engine and was wondering while I have them off, can I get the dent on the left exhaust pipe pulled somehow? or is there a better suggestion? I would really like to keep them as they sounded great.It might be hard to see the dent, but is right up against the shock tower as that is what caused the dent in the first place.[​IMG]
    I would appreciate any input you might have, and I can and will be posting more pics once I get back to my shop on the weekend. Thanks a lot.
    p.s. really love the sounds these bad boys make, that and the fact that they maintain the symmetry of the bike with 4 into 2
