OEM Petcock Rebuild Service....Cores Needed
markus56 Nov 30, 2010
  1. oFLiUF
    oFLiUF Member
    Right! Rather than opening a new topic I decided it would be best to ask here... There're two gas lines coming from my 600 petcock - there's the thick hose going "into" the bike and a smaller one coming out of the side (towards the back of the bike)... Which one should take the filter?
    Also would it be a problem if the filter is a bit/a lot tilted (not sure how much space I've got)?
    Q3: Since I'm not really good with imperial measurements which Pingel filter model fits the 600 fuel line 5/16" or the 3/8"? Guess that's the diameter of the hoses described above?
  2. furchin
    2,054
    39
    You should not have two gas lines. One line (larger of the two) is the gas line feed. You will put a filter in this line. The other line (smaller) should be your vacuum line to operate the petcock. Don't know the line size for the filter you ask about.
    oFLiUF likes this.
  3. oFLiUF
    oFLiUF Member
    Got it! Now that I know which hose does what, I guess I'll be able to figure out the filter size... Thanks!
    Cheers! V@
  4. furchin
    2,054
    39
    Good Luck.
    7,744
    283
    :hello: You want a 5/16" I.D. & not the 3/8" in line filter. ID= inside diameter.
  6. badbrad
    badbrad Senior Member
    1,024
    14
    123
    Got any rebuilt valves Markus? Don’t feel like ordering all the required parts!
  7. markus56
    3,191
    134
    Yes sir, I have 900 and 1000 valves ready to go. I'll send you a PM
