Need to Bleed??
jgonzo Sep 23, 2011
  1. jd2ndzl
    jd2ndzl Member
    15
    13
    Changed brake fluid found return port plugged brakes working good now. Clutch would start slipping bad the more I rode was good when it was cold out. Changed fluid and found return port plugged bad too went for ride and clutch locked in tight with zero slipping. Just wanted to put up results in hopes that it helps someone else with problems glad I didn’t start tearing clutch apart. Thanks everyone for help.
    351
    Those fluids get nasty over the years. Every year or two a quick fluid swap is much easier to deal with than going through the complete system and scrubbing the grunge out when they start acting up.
    Furchin for the win on diagnosis!
  3. furchin
    2,172
    95
    Good to hear that everything is working as it should now.
