need a little help
probike Sep 20, 2018
  1. probike
    probike New Member
    7
    does anyone know what adapter plate to use when ordering for a pingel petcock
    im surpose to remove the tank and measure center to center on the two bolts that holds the stock one on
    was hoping someone already did the change over.its something like 40 or 44mm
    p.s just being lazy and dont wanna remove the tank
  2. Harriminator
    786
    146
    Ever tried here the search-function using 'Pingel'? Enough hits...:laughing7:
  3. furchin
    2,094
    54
    "p.s just being lazy and dont wanna remove the tank"
    You will create much more work by leaving the tank in place. Along with the adapter plate, you will have to file out a very small round section of the tank so the pingel will fit because the filter is round and not oval like oem.
  4. 87kawzl
    121
  5. probike
    probike New Member
    7
    Having trouble download ing the owners manual need help changing brake pads on a zl900 can someone please send it to my email mjdj16@bellsouth.net
  6. furchin
    2,094
    54
  7. DirtyRider
    DirtyRider Member
    87
    7
    If you look on the pingel webpage it tells you which one
