Motion Pro Throttle cables for the ZL 900
Ducky Dog Jul 6, 2018
  1. Ducky Dog
    Ducky Dog Active Member
    177
    20
    I just spoke with Motion pro and they have ZL 900 throttle cables in stock
    part # 03-0141 is the pull cable with the bar on it, which is removable to make the same part # a push cable
    $26.99 each
    or maybe you guys knew that already.
    87kawzl Senior Member
    1,359
    85
    Too bad they want to rape the 1k owners for an extra 8"
  3. markus56
    3,191
    134
    Yeah, it's double that for ZL1k cables. They'll tell you that being a special made cable warrents the extra cost. I've looked closely at the two and I can't see a thing different about the 900 or 1000 hardware but they swear they're different.
  4. GaryD
    GaryD Active Member
    291
    16
    Won't VN cables fit?
  5. 87kawzl
    1,359
    85
    Doubt it would even be close with a v-twin
  6. Ducky Dog
    177
    20
    I dont know what to tell you guys
    8" is a lot more to take,,,,, You pay extra!
  7. markus56
    3,191
    134
    Vulcan won't work
  8. GaryD
    GaryD Active Member
    291
    16
    Must be another Kawasaki out there that's uses similar.
    Kawasaki were pretty good at using the same parts across their range.
  9. Ducky Dog
    177
    20
    I recieved the MotionPro cables the other day
    they look good and have an extra adjuster mid cable
    down side is the fittings are not chrome just zinc plated
