Looking for a steady idle with no miss
badbrad Jan 6, 2019
  1. Ed
    Ed Active Member
    204
    Bench synced carbs have always worked well for me. They'd only show a discrepancy with vacuum syncing if the compression or valve lash weren't fairly even across all cylinders. Can't do much about compression but as mentioned, valve lash should be checked beforehand or leave it as is. If it idles and revs fine with just a bench sync, that's a good sign.
  2. markus56
    3,328
    174
    Way to stay after it Brad......glad you've got it running good.
    R. J. and badbrad like this.
