KAWASAKI ZL1000 IGNITION SWITCH AND WIRING NEEDED...
madaboutdeltics Oct 30, 2018
  1. madaboutdeltics
    madaboutdeltics Member
    Hi All
    First post on here for help.
    My pride and joy was recently stolen and vandalised (luckily the coppers turned up before they could get away with it) but unfortunately i need a new ignition switch and the wiring underneath.
    i ordered a switch from the States, (im in Manchester, England) and it eventually turned up without the wiring attached, so i need either or.
    Parts are impossible to source other here, and it is discontinued by Kawasaki.
    Can anybody help ? will pay for it, not asking for a freebie.
  2. prfixer
    1,380
    44
    I have one that does not have a key. You can get a key made or transfer the bottom to your switch. It's pretty intricate in there though, it would be safer to let a locksmith make a new key.
  3. madaboutdeltics
    That looks perfect mate, i will PM you...
  4. markus56
    3,258
    153
    I agree, it would be better to have a key made than to take it apart if you've never had one apart before.
  5. prfixer
    1,380
    44
  6. PTPopz813
    PTPopz813 Member
    66
    I am not sure where it is but there is a code on the lock that says what key it takes... you send them that code and they will cut the key to fit that lock.
  7. prfixer
    1,380
    44
    There is a "Z" stamped on the switch. However, the one locksmith I referred to previously said there may be problems with those codes and the cutting instructions available to him. Something about secondary cuttings, above my pay grade! Brian needed it shipped ASAP, so we didn't wait and see if a key cut by the number would have worked. There is also kawasakikeys.com that is available to dealers and I wonder if that isn't a better option.
    PTPopz813 likes this.
