Kawasaki Factory Paint Codes
R. J. Aug 9, 2018
    7,744
    283
  2. GaryD
    GaryD Active Member
    291
    16
    Hmm...maybe the old ZL should be candy burnt orange!!!:whistling:
  3. furchin
    2,054
    39
    R.J., I copied your link to the proper section. Don't know why you could not post it.
  4. 87kawzl
    87kawzl Senior Member
    1,359
    85
    Don't see ZL paint listed, no Wine berry, black or zl 9 red, yellow zl6 listed unless I just don't see it. Nice link though, thanks RJ.
    7,744
    283
    :hello: Thank's Martin.
  6. markus56
    3,191
    134
    Luminous Vintage Red is the color for the red 1k.
    7,744
    283
    :hello: So the red ZL 10 colorcode is P5 & it's color number is 2099 in Luminous Vintage Red.
  8. PTPopz813
    PTPopz813 Member
    57
    The name of the 1985 ZL900 from what I am told is Luminous Red Metalic. finding that info on-line is imposible
  9. markus56
    3,191
    134
    R.J. is right on the ZL1000 and the ZL 900 is Luminous Red. There's no metalic in the name I don't believe.
    7,744
    283
    :hello: While as far as PPG paint goes they do not list any of the paint codes that is on this list. They have only 3 bike colors listed in PPG file paint codes.
  11. Ed
    Ed Active Member
    111
    11
    7,744
    283
    :hello: I've been looking for Honda Topaz orange which is a 3 stage paint. I found a seller on E-bay that says he has a good match using PPG paint. He wants $135 a pint or $185 a qt. So I'd need to get a qt of each of the base silver & a qt of the candy orange. I'm painting 2 bikes this color. My local PPG dealer tells me they can match it in either 2 or 3 stage paint for $130 a qt. This guy on E-bay has already proven his paint matching. I've seen a lot of his pics of jobs that he has done on E-bay.https://www.ebay.com/itm/CANDY-TOPA...h=item33ae9a077d:g:xDcAAOSwhkRWdL9T:rk:1:pf:0 IMG_6816.JPG IMG_6817.JPG s-l1600 (10).jpg IMG_6818.JPG IMG_6819.JPG IMG_6821.JPG The bad thing about cany paint is it always looks different under different lighting.
  13. 87kawzl
    1,359
    85
    "The bad thing about cany paint is it always looks different under different lighting."
    Isn't that the great thing about it as well!
    7,744
    283
    :hello: Yes except when trying to match it. :laughing7:.
  15. mick
    mick Senior Member Supporting Member
    62
    103
    Hi Guys , I have posted this document before. It lists the Red 1k colour, Candy Wine Red, the Black as Ebony and the Blue as Cosmic Galaxy Blue.
    Along time ago, when I had a Blue 1K , it needed some repairs. The Guys at Colidescope said it was unusual as it had a black base with the blue metalic overlayed.
  16. JayMcC
    JayMcC New Member
    ZL 900 RedCode is L1. Candy Cardinal Red. I believe this is the Code marked on the back of the lower Rear Case in Grease Pencil as the Pic above shows.
    Mine's Red... The Chip is damn close.
    PTPopz813 and R. J. like this.
  17. JayMcC
    JayMcC New Member
    L1/2024 Candy Cardinal Red is also used on the 2001 Drifter and 2002 Mean Streak also...
  18. GaryD
    GaryD Active Member
    291
    16
    So what colour is L6?
    Surprised they write the code on an engine.
    Are you sure this doesn't refer to any of the shims for the shaft?
  19. JayMcC
    JayMcC New Member
    Just a guess on the grease pencil mark on the case. But I guess not. But the red color code I'm pretty sure is L1/2024 candy cardinal red. Maybe just coincidence with the marks on the case.
    On the other hand, L1 and L2 are Reds. It wouldn't be inconceivable that Kawasaki is using a red not listed.
  20. JayMcC
    JayMcC New Member
