Is It In My Head?
ZLrider May 7, 2018
  1. ZLrider
    ZLrider Well-Known Member
    534
    9
    53
    What I'm referring too I don't think you'd call a donut. It's more of a sleeve and I don't think you could crush it if you tried. I could be wrong though, I know you have a much better knowledge of these machines than I. It's been quite some time now since I had the exhaust apart, but seems to me the issue was the split in the sleeve is lined up with a split in the exhaust and should be rotated a bit. It's not very loud at all and to be clear I'm not talking about where the pipe bolts to the head, I think it's where the muffler connects to the head pipe. The connection is under the bike, not in the front.
    87kawzl Well-Known Member
    1,077
    49
    93
    The gasket you are referring to is a graphite gasket. They will seal during re-assembly if you were careful with them while working on the connection. They should be slid on the male pipe all the way to the stop collar when you install them and make sure the female pipe is not crimped down (open it up with a wooden handle from a shovel or hammer) before assembly so you don't rip the gasket. They are expensive to replace if you bang them up.
    7,195
    194
    108
    :hello: I wasn't sure of the name. They run about $22 each. When I was working on a friends (Dan) ZL 1000 from Tampa FL I had one just fall apart. It wasn't on right & was hard to get off.
  4. ZLrider
    534
    9
    53
    Thanks for the tips. It's not a pressing issue, but when I get around to pulling that stuff apart again will refer to these comments. I've always had a so-so memory, but I can't for the life of me think of why I had those pipes apart. I've really not had to do much to this machine.
