  1. 87kawzl
    123
    You re-used the head gasketo_O?
  2. The Original Sin
    218
    20
    Yeah I know.... duh! But it looked in great shape. Wishful thinking I guess. I’m just throwing money at this thing right now. It’s no longer a matter of passion it’s become an expensive obsession.
    335
    :hello: No problem. Glad to help. :notworthy:. You should always use a new head gasket. They crush down & will fill in very slight imperfections on the head or top of the cyns. Also I always have my friend Ron A. check my heads & top of the cyns for warpage.
  4. The Original Sin
    218
    20
    Is there any way for coolant to enter the crankcase other than through the water pump and or the top end?
    335
    :hello: I'm not really sure. One of the long head bolts that bolts at the cyn botton to crank cases has an orange O-ring that may go bad but I think that is an oil issue.
  6. The Original Sin
    218
    20
    My new engine arrives today, any words of wisdom? Drilling a said hole in the oil pan has me a little perplexed.
  7. markus56
    3,260
    154
    That is an easy one. You've got to swap out the oil pans anyway and when you take them both off and compare the two, you'll easily see the hole and how big it needs to be and where to drill it.
  8. The Original Sin
    218
    20
    Thanks Markus. I’ll keep you posted. Btw I’ve watched you engine swap video a dozen times. You certainly had a nice group of Eliminator experts with you.
  9. markus56
    3,260
    154
    Yes, we had a gathering of great guys on that swap.
  10. Ed
    Ed Active Member
    142
    19
    The problem may have started with a leaky coolant reserve tank. The nipple at the bottom of many tanks have sharp edges from the mold halves not matching precisely and poorly trimmed afterwards in an attempt to remove the flashing. I always used an xacto to round out those sharp edges as much as possible on those type of tanks and some were pretty bad.
    A properly designed tank will have all tubes going in thru the top, IMO.
  11. The Original Sin
    218
    20
    I never thought of that. You guys are the best!
    335
    :hello: When I was working on my friend Ron D. ZL 10 coolant was leaking out the bottom stem. It had a slight crack in it. I had a spare so I just gave it to him. The 250 Eliminator does not have a stem on the bottom.
  13. The Original Sin
    218
    20
    I am struggling big time installing the new engine!!!!! Anybody out there who can help!? Tips, best practices. Tricks, voodoo magic. HELP!
  14. markus56
    3,260
    154
    Do you have the swing arm in place or removed? You can do it either way but it's easier with it out of the way. You should have your oil pan swapped out too before installing engine. What all are you having trouble with?
  15. The Original Sin
    218
    20
    The swing arm is off. The oil pan is swapped. I’m getting hung up. I guess I’ll need to take off the motor mounts front and back, try and get the engine in the frame supported underneath with a jack then put the mounts back on. What side of the engine do you enter?
  16. markus56
    3,260
    154
    The right side after removing the frame section.
    335
    :hello: To me it's a 2 man job. Do you have anyone that could help you.
  18. The Original Sin
    218
    20
    Yeah, my son...after he’s finished with finals. Thanks for asking R.J.
  19. R. J.
    335
    :hello: The 2 motors that I've installed I used my Harbor Frieght mini tranny jack. $90. It made things so much easier. tranny_jack-1.gif
  20. The Original Sin
    218
    20
    Wow! That’s great! I’ll be doing a swap on my red bike next year so it will probably be a good investment.
