Installing the Head Pipes
The Original Sin Dec 18, 2018
  1. The Original Sin
    228
    20
    I’m struggling a little reinstalling the head pipes into the front of the engine. Is it better to loosely bolt the exhaust chamber in place or leave in hanging until the pipes are secure. What about the two outside pipes? I’m having a hell of a time getting them to seat with those plastic radiator shrouds in place. What works best for you?
  2. markus56
    3,328
    174
    You need to remove those plastic shroud pieces and get 'em outta' your way for now and install when you get the exhaust bolted up. Then set the four pipes and power chamber in place and rest the power chamber on something that will put it close to bolting up but not quite. Power chamber will bolt in place after you get the head pipes in place and snugged up. The outside pipes will swing into place at the same time. Put some high tack on the copper gaskets to keep them in place while you're wiggling. Exhaust bolts at head will tighten a little at a time each till the get very snugg.
  3. Harriminator
    881
    193
    I always put some bubble wrap on the frame to avoid scratches by the outside pipes; the 'plastic-shroud-oil-line-get-into-right-place-thing' is really a puzzle...:cussing:
