Fuel injecting my ZL1000
GaryD May 14, 2018
  1. GaryD
    GaryD Active Member
    271
    15
    Took a chance and got some 2008 Z750S Thottles.
    Hey prosto they the y are pretty much spot on...
    7,551
    251
    :hello: Most likely you will need all the electronics/electrical from what ever bike that they come from.
  3. GaryD
    GaryD Active Member
    271
    15
    Looked at that and it would be a nightmare.
    Just going with a Megasquirt. It will happily run with just the bare minimum sensors.
  4. 87kawzl
    87kawzl Senior Member
    1,281
    67
    What are you planning on using for fuel pump?
  5. GaryD
    GaryD Active Member
    271
    15
    Pretty sure I've seen a couple of kawasaki ones thjat live outside the tank. Just need to do a bit of research.
  6. Harriminator
    698
    101
    :hello::laughing7::
    Btw R. J.: what's the DRIFTER story?
  7. GaryD
    GaryD Active Member
    271
    15
  8. Harriminator
    698
    101
  9. 87kawzl
    1,281
    67
    Looks like a fun project! should run nice and smooth.
    7,551
    251
    :hello: The 1999 VN 1500 Drifter is done. After doing it I found out that DFI is a nightmare to work on when something goes wrong. It ended up a 4 week prodject. Half of that was waiting on parts. Would a stock ZL tank be able to be used for a DFI conversion.
  11. Harriminator
    698
    101
    7,551
    251
    :hello: I see no advantage to going to DFI. My ZL has always been spot on. No hesitation what so ever throughout the throttle range.
  13. Harriminator
    698
    101
    7,551
    251
    :hello: That most likely would work on the 250 Eliminator. At a GRAND I'll pass. :laughing7:.
  15. Harriminator
    698
    101
    :hello:...and for the big ZLs you'll need 2GRANDs aka 2kits; that'd be awesome: when installed you put a switch on the handlebar to change between 2LH or 2RH cylinders when in cruisin' mode or like Burger King says: have it your way...hahaha. :rotf:
  16. GaryD
    GaryD Active Member
    271
    15
    I understand where your comming from R.J. but I want to know how F.I. works and I've always learnt things by doing it.
  17. GaryD
    GaryD Active Member
    271
    15
    Just found the first issue I didn't anticipate. This is the first Kawasaki that I've worked on that doesn't bolt the carb rubbers to the head!!!! It's a straight rubber tube clamped to the head.
    Now have to ponder how I'm going to fix the throttle bodies to the head...as all the current Kawasakis mate their injection bodies via a bolt-on rubber.
