Discontinued Part Numbers - 1985 Kawasaki Eliminator ZL900
Jarney May 22, 2013
  1. Jarney
    4,475
    13
    Discontinued Part Numbers - 1985 ZL900
    Ok, here is the list of part numbers that are considered discontinued or no longer available for the 1985 Kawasaki Eliminator ZL900. This information was taken straight from Kawasaki's website. Most of this stuff is just nuts and bolts and washers, etc. There are some parts listed that have "Active" part numbers due to parts being "Superceded" - which I think is just beause Kawasaki does not always have their website up to date. There are also some part numbers that have other notes such as "See Dealers Substitute Parts List", "Interchangeable With Part Number XXXX" and "Limited Quantity".
    This list will allow us to search on this site for these part numbers without going through everything on Kawasaki's website or relying on other parts sites and their fiches - which a lot of times will list parts as Active, when really they are not - again, websites are not always up to date. In the future if you find a part number that has become discontinued, obsolete, interchangeable, no longer available, or just something that I missed, contact an administrator or moderator and we can edit this list as needed. Later.
    This list can be discussed in the following thread:
    http://www.zl-oa.com/forums/showthre...nator-ZL-parts
    Current as of 5/19/2013
    Discontinued Part Numbers for the 1985 Kawasaki Eliminator ZL900
    AIR CLEANER
    224C0614 SCREW-PAN-WP-CROS Active limited quantity
    OR 224AB0614 Active
    11010-1261 FILTER-ASSY-AIR
    11010-1263 FILTER-ASSY-AIR
    11012-1370 CAP,AIR FILTER
    11012-1448 CAP, AIR FILTER
    USE 11012-1485 Active
    13091-1378 HOLDER,ELEMENT
    14073-1099 DUCT,AIR FILTER
    92005-1136 FITTING
    92059-1162 TUBE,VACUUM,LONG
    USE 92059-1916 ACTIVE
    92059-1365 TUBE,4X9X80
    USE 92190-1062 ACTIVE
    92059-1569 TUBE
    92059-1570 TUBE
    92059-1572 TUBE,LH
    92059-1573 TUBE,RH
    92059-1622 TUBE
    92071-1129 GROMMET,AIR FILTER
    BATTERY CASE
    130B0610 BOLT,FLANGED,6X10
    USE 130AA0610 ACTIVE
    130C0610 BOLT-FLANGED,6X10,BLA
    USE 130AB0610 ACTIVE
    130C0612 BOLT-FLANGED,6X12
    USE 130BB0612 ACTIVE
    OR 130AB0612 ACTIVE
    132E0625 BOLT-FLANGED-SMALL
    USE 92002-1612 ACTIVE
    132G0825 BOLT-FLANGED-SMALL
    USE 132BA0825 ACTIVE
    220B0510 SCREW PAN HEAD 5X10
    USE 220AA0510 ACTIVE
    224C0520 SCREW-PAN-WP-CROS
    USE 224AB0520 ACTIVE
    11012-1447 CAP,BATTERY
    11044-1293 BRACKET,GUSSET COVER
    11044-1424 BRACKET
    14024-1075 COVER,FUEL TANK,LH
    14024-1076 COVER,FUEL TANK,RH
    14041-1062 COVER-COMP,HANDLE HOL
    32097-1117 CASE-BATTERY
    32109-1127 GRIP-FRAME,LWR,LH
    32109-1128 GRIP-FRAME,LWR,RH
    32109-1129 GRIP-FRAME,UPP
    35011-1251 STAY,MUFFLER,LH
    35011-1252 STAY,MUFFLER,RH
    56031-1419 LABEL-MANUAL,IGNITION
    92009-1663 SCREW
    USE 92009-3805 ACTIVE
    92037-1670 CLAMP,BRAKE HOSE
    92037-1685 CLAMP
    92037-1711 CLAMP,HOSE
    92072-1183 BAND,BATTERY
    92072-1191 BAND,BATTERY
    BRAKE PEDAL
    236B0410 SCREW-PAN-WSP-CROS
    11044-1257 BRACKET,BRAKE PANEL
    13169-1940 PLATE,BRAKE SWITCH
    43001-1202 LEVER-BRAKE,PEDAL
    43004-1113 SHAFT-BRAKE
    92081-1590 SPRING,STEP RETURN
    BREATHER COVER/OIL PAN
    132J0625 BOLT-FLANGED-SMALL
    USE 92150-1779 ACTIVE LIMITED QUANTITY
    OR 132BB0625 ACTIVE
    132J0640 BOLT-FLANGED-SMALL
    USE 132BB0640 ACTIVE
    235B0610 SCREW-PAN-WP-CROS
    USE 235AA0610 ACTIVE
    411F0600 WASHER PLAIN
    USE 411AB0600 ACTIVE
    11009-1861 GASKET,BREATHER BODY
    USE 11061-1102 ACTIVE
    14070-1061 BODY-BREATHER
    27010-1155 SWITCH,OIL PRESSURE
    USE 27010-1313 ACTIVE
    49034-1069 PAN-OIL
    92062-1057 NOZZLE,YELLOW
    Interchangeable With Part 92062-1080
    CABLES
    220C0514 SCREW-PAN-CROSS,5X14 1
    USE 220AB0514 ACTIVE
    54001-1117 CABLE-SPEEDOMETER
    USE 54001-1143 ACTIVE
    CAMSHAFTS/CHAIN/TENSIONER
    120P0614 BOLT,6X14
    USE 120CA0614 ACTIVE
    130G0835 BOLT,FLANGED,8X35
    USE 130CA0835 ACTIVE
    OR 130BA0835 ACTIVE
    OR 132BB0625 ACTIVE
    12053-1116 GUIDE-CHAIN,RR
    92002-1302 BOLT
    USE 92150-1380 ACTIVE
    CANISTER
    130E0608 BOLT-FLANGED
    USE 130N0608 ACTIVE
    132J0608 BOLT-FLANGED-SMALL
    USE 132BB0608 ACTIVE
    11044-1333 BRACKET,SEPARATOR
    92059-1574 TUBE,4X9X640,WHITE
    92059-1575 TUBE,7X12X553,GREEN
    92059-1576 TUBE,7X12X520,YELLOW
    92059-1577 TUBE,5X10X140,BLUE
    USE 92190-1007 ACTIVE
    92059-1650 TUBE,5X10X550,RED
    92059-1651 TUBE,5X10X530,BLUE
    92072-066 BAND,TOOL
    USE 92072-1419 ACTIVE
    CARBURETOR ASSY
    223C0510 SCREW-PAN-WS-CROS
    USE 223AB0510 ACTIVE
    15001-1175 CARBURETOR-ASSY
    15001-1177 CARBURETOR-ASSY
    15002-1181 CARBURETOR,LH,OUTSIDE
    15002-1182 CARBURETOR,LH,INSIDE
    15002-1183 CARBURETOR,RH,INSIDE
    15002-1184 CARBURETOR,RH,OUTSIDE
    15002-1185 CARBURETOR,LH,OUTSIDE (CANADA)
    15002-1186 CARBURETOR,LH,INSIDE (CANADA)
    15002-1187 CARBURETOR,RH,INSIDE (CANADA)
    15002-1188 CARBURETOR,RH,OUTSIDE (CANADA)
    15002-1189 CARBURETOR,LH,OUTSIDE
    15002-1190 CARBURETOR,LH,INSIDE
    15002-1191 CARBURETOR,RH,INSIDE
    15002-1192 CARBURETOR,RH,OUTSIDE
    16021-1101 SCREW-THROTTLE STOP
    92001-1998 BOLT,THROTTLE ADJUST
    92005-1108 FITTING,FUEL,T-TYPE
    92005-1109 FITTING,FUEL,I-TYPE
    USE 92005-1310 ACTIVE
    92005-1135 FITTING,T-TYPE
    92059-1236 TUBE,FUEL
    USE 92190-1063 ACTIVE
    92059-1633 TUBE,6.5X9.5X190
    CARBURETOR PARTS
    223C0416 SCREW-PAN-WS-CROS
    USE 223AB0416 ACTIVE
    225C0418 SCREW-PAN-WSP-CROS
    USE 225AB0418 ACTIVE
    16009-1271 NEEDLE-JET,N27N
    16017-1288 JET-NEEDLE,01D32
    CHASSIS ELECTRICAL EQUIPMENT
    130B0608 BOLT,FLANGED,6X8
    USE 130AA0608 ACTIVE
    130C0812 BOLT-FLANGED,8X12,BLA
    USE 130AB0812 ACTIVE
    225B0620 SCREW-PAN-WSP-CROS
    USE 225AA0620 ACTIVE
    410B0400 WASHER PLAIN 4MM
    USE 410AA0400 ACTIVE
    11045-1385 BRACKET,RELAY&COUPLER
    26001-1731 HARNESS,MAIN
    26011-1313 WIRE-LEAD,BRAKE SWITC
    26011-1329 WIRE-LEAD,BATTERY(+)
    26011-1330 WIRE-LEAD,BATTERY(-)
    27003-1229 HORN,LH
    27003-1230 HORN,RH
    27010-1069 SWITCH,RESERVE LIGHTING
    USE 27010-1066 ACTIVE
    49016-1050 COVER-SEAL
    92002-1262 BOLT,6X22
    USE 92001-1774 ACTIVE
    92037-1069 CLAMP,WIRING HARNESS
    USE 92171-0652 ACTIVE
    CLUTCH
    120S0616 BOLT-SOCKET,6X16,BLACK
    USE 120CB0616 ACTIVE
    13081-1221 CLUTCH-ASSY
    13107-1161 SHAFT,BEVEL GEAR,FR
    13116-1118 ROD-PUSH,CLUTCH
    USE 13116-0006 ACTIVE
    13231-1067 RELEASE-ASSY-CLUTCH
    USE 13231-1072 ACTIVE
    39130-1054 SPRING-LEAF
    See Dealer's Substitute Parts List
    43056-1052 BREATHER-BRAKE
    USE 43056-1056 ACTIVE
    92002-1613 BOLT
    USE 92002-1344 ACTIVE LIMITED QUANTITY
    OR 92154-0497 ACTIVE
    92015-1538 NUT
    92026-5001 SPACER
    CLUTCH MASTER CYLINDER
    27010-1171 SWITCH,CLUTCH
    USE 27010-1406 ACTIVE
    43015-1306 CYLINDER-ASSY-MASTER,
    43026-1052 CAP-BRAKE,FR ACTIVE LIMITED QUANTITY
    43059-1308 HOSE-BRAKE
    43059-1309 HOSE-BRAKE
    46092-1129 LEVER-GRIP,CLUTCH
    49006-1041 BOOT,DUST
    92002-1324 BOLT,SOCKET,6X10
    USE 92153-0417 ACTIVE
    92002-1593 BOLT
    USE 92153-0627 ACTIVE
    43067-001 WASHER-OIL BOLT
    USE 49091-0001 ACTIVE
    92037-1687 CLAMP
    92072-1190 BAND
    CRANKCASE
    132G0612 BOLT-FLANGED-SMALL
    USE 92150-1599 ACTIVE LIMITED QUANTIY
    OR 132BA0612 ACTIVE
    132G0625 BOLT-FLANGED-SMALL
    USE 132BA0625 ACTIVE
    132G0630 BOLT-FLANGED-SMALL
    USE 132BA0630 ACTIVE
    172G0616 STUD 6X16
    USE 172BA0616 ACTIVE
    410B0600 WASHER PLAIN 6MM ACTIVE LIMITED QUANTITY
    OR 410AA0600 ACTIVE
    11012-1454 CAP
    12053-1138 GUIDE-CHAIN
    14004-5190
    14013-1006 RING-POSITION
    92001-1871 BOLT,BANJO,12X23
    USE 92153-1976 ACTIVE
    92042-016 PIN DOWEL 6MM
    USE 92043-1690 ACTIVE
    OR 92043-1690 ACTIVE
    92059-1508 TUBE
    92066-1204 PLUG,BALANCER
    92081-1668 SPRING
    USE 92145-0669 ACTIVE
    CRANKCASE BOLT PATTERN
    410B0800 WASHER PLAIN 8MM
    USE 410AA0800 ACTIVE
    92150-1164 BOLT,8X140
    CRANKSHAFT
    130G0825 BOLT-FLANGED,8X25
    USE 130BA0825 ACTIVE
    12046-1067 SPROCKET,21T
    92028-1100 BUSHING,CRANKSHAFT
    USE 92028-1917 ACTIVE
    92028-1101 BUSHING,CRANKSHAFT
    USE 92028-1918 ACTIVE
    OR 92028-1918 ACTIVE
    92028-1102 BUSHING,CRANKSHAFT
    USE 92028-1919 ACTIVE
    92028-1272 BUSHING,CRANKSHAFT,BL
    USE 92139-1068 ACTIVE
    92028-1273 BUSHING,CRANKSHAFT,BL
    USE 92139-1069 ACTIVE
    92028-1274 BUSHING,CRANKSHAFT,BR
    USE 92139-1070 ACTIVE
    CYLINDER/PISTONS
    551A1012 PIN-DOWEL
    11005-1447 CYLINDER-ENGINE
    11007-1063 LINER-CYLINDER
    11009-1505 GASKET,CYLINDER BASE
    USE 11009-1847 ACTIVE
    13001-1205 PISTON-ENGINE,STD
    USE 13001-1206 ACTIVE LIMITED QUANTITY
    CYLINDER HEAD
    120S0610 BOLT-SOCKET
    USE 120CB0610 ACTIVE
    130G0630 BOLT,FLANGED,6X30
    USE 130BA0630 ACTIVE
    OR 130AA0630 ACTIVE
    130J0625 BOLT-FLANGED,6X25
    USE 130BB0625 ACTIVE
    16065-1134 HOLDER-CARBURETOR
    92002-1486 BOLT,11X164
    USE 92150-1075 ACTIVE
    92004-1116 STUD,10X158
    CYLINDER HEAD COVER
    11009-1905 GASKET,REED VALVE
    USE 11009-1857 ACTIVE
    11012-1476 CAP,REED VALVE
    92150-1447 BOLT
    USE 92153-0793 ACTIVE
    92150-1447 BOLT
    DRIVE SHAFT/FINAL GEARS
    130X0812 BOLT-FLANGED
    USE 130AD0812 ACTIVE
    220B0430 SCREW-PAN-CROS
    USE 220AA0430 ACTIVE
    11021-1057-F2 CASE-ASSY,FINAL GEAR,
    13101-1070-F2 GEAR-ASSY,FINAL,G.SIL
    13101-5051 GEAR-ASSY,REAR BEVEL
    39158-1061 SHAFT-ASSY-DRIVE
    42034-1092 COUPLING,PROPELLER SH
    USE 42034-1178 ACTIVE
    92055-1037 "0" RING,I.D=32.7MM ACTIVE LIMITED QUANTITY
    ENGINE COVERS/GUARDS
    130J0610 BOLT-FLANGED
    USE 130BB0610 ACTIVE
    132J0620 BOLT-FLANGED-SMALL
    USE 132BB0620 ACTIVE
    OR 132BB0625 ACTIVE
    132J0655 BOLT-FLANGED-SMALL
    USE 132BB0655 ACTIVE
    132J0860 BOLT-FLANGED-SMALL,8X
    USE 132BB0860 ACTIVE
    132J0890 BOLT-FLANGED-SMALL
    USE 132BB0890 ACTIVE
    220C0608 SCREW-PAN-CROS,6X8
    USE 220AB0608 ACTIVE
    11009-1863 GASKET,COVER,LH
    USE 11061-1155 ACTIVE
    11009-1860 GASKET,CLUTCH COVER
    USE 11061-1154 ACTIVE
    11044-1291 BRACKET,LH
    11044-1292 BRACKET,RH
    13169-1956 PLATE,GUARD
    14025-1740 COVER,SOUND ARRESTER
    14025-1814 COVER,CLUTCH COVER
    51061-1051 PAD-KNEE,LH
    51061-1052 PAD-KNEE,RH
    55020-1201 GUARD,LH
    55020-1202 GUARD,RH
    92022-104 WASHER PL 5.5X20X1.2
    USE 92022-1405 ACTIVE
    92066-1218 PLUG,COVER,LH
    USE 92066-1397 ACTIVE
    92075-1708 DAMPER,SOUND
    92075-1756 DAMPER
    92075-1757 DAMPER
    92075-1779 DAMPER
    FENDERS
    112B0622 BOLT 6X22
    USE 112BA0622 ACTIVE
    130B0614 BOLT
    USE 130AA0614 ACTIVE
    130B0620 BOLT,FLANGED,6X20
    USE 130P0620 ACTIVE LIMITED QUANTITY
    OR 130CA0620 ACTIVE
    OR 130BA0620 ACTIVE
    OR 130AA0620 ACTIVE
    32098-1066 CASE-TOOL
    35004-1175-H8 FENDER-FRONT,EBONY
    35004-1175-7V FENDER-FRONT,L.RED
    35023-1141 FENDER-REAR,FR
    35023-1142 FENDER-REAR,RR
    35023-1143-H8 FENDER-REAR,UPP,EBONY
    35023-1143-7V FENDER-REAR,UPP,L.RED
    92027-251 COLLAR ACTIVE LIMITED QUANTITY
    FOOTRESTS
    120Z0514 BOLT-SOCKET
    USE 120CD0514 ACTIVE
    130C1220 BOLT-FLANGED
    132G0616 BOLT-FLANGED-SMALL
    USE 132BA0616 ACTIVE
    411B0600 WASHER PLAIN 6MM ACTIVE LIMITED QUANTITY
    OR 411AB0600 ACTIVE
    OR 411AA0600 ACTIVE
    482L5000 CIRCLIP-TYPE-E,5MM
    USE 482EA5000 ACTIVE
    34003-1240 HOLDER-STEP,RR
    34003-1241 HOLDER-STEP,FR,LH
    34003-1242 HOLDER-STEP,FR,RH
    34028-1159 STEP,RR,RH ACTIVE LIMITED QUANTITY
    34028-1162 STEP,FR,LH
    34028-1163 STEP,FR,RH ACTIVE LIMITED QUANTITY
    34028-1164 STEP,FR,RUBBER
    55020-1197 GUARD
    92043-1144 PIN,12X37
    USE 92043-1641 ACTIVE
    FRAME
    131S0820 BOLT-FLANGED
    131S0825 BOLT-FLANGED
    32002-1849 FRAME-COMP
    39051-1051 FRAME-COMP-SIDE
    92002-1611 BOLT
    USE 92150-1672 ACTIVE
    FRAME FITTINGS
    32029-1406 BRACKET-ENGINE,RR,UPP
    32029-1427 BRACKET-ENGINE,FR,LH
    32029-1428 BRACKET-ENGINE,FR,RH
    92002-1360 BOLT
    92002-1530 BOLT,FLANGED,10X280
    USE 92151-1916 ACTIVE
    92002-1532 BOLT,FLANGED,8X30
    92015-1517 NUT
    92015-1518 NUT
    92019-021 NUT,LOCK,10MM
    USE 92210-1184 ACTIVE
    92027-1990 COLLAR,L=24.8
    92075-1730 DAMPER,ENGINE MOUNT
    92075-1731 DAMPER,ENGINE MOUNT
    FRONT BEVEL GEARS
    130S0625 BOLT-FLANGED,6X25,BLA
    USE 130CB0625 ACTIVE
    11009-1532 GASKET,BEVEL GEAR CAS
    USE 11061-0157 ACTIVE
    11012-1477 CAP,BEARING
    13048-1005 CAM,DAMPER
    13101-1113 GEAR-ASSY
    13101-5050 GEAR-ASSY,FRONT BEVEL
    13151-1007 SWITCH,NEUTRAL
    USE 13151-1080 ACTIVE
    52005-1057 GAUGE,OIL LEVEL
    USE 52005-0071 ACTIVE
    92002-1583 BOLT,6X50
    USE 92153-0915 ACTIVE
    92002-1585 BOLT,6X105
    USE 92153-0917 ACTIVE
    FRONT BRAKE
    41080-1112 DISC,FR,SILVER
    43041-1194 CALIPER-ASSY,FR,LH
    43041-1471 CALIPER-ASSY,FR,RH
    43049-002 RING,PISTON SEAL
    USE 43049-1098 ACTIVE
    43056-003 BREEDER
    USE 43085-001 ACTIVE
    92001-1951 BOLT,SOCKET,8X30
    USE 92150-1771 ACTIVE
    FRONT FORK
    220B0406 SCREW PAN HEAD 4X6
    USE 220AA0406 ACTIVE
    11012-1473 CAP,FORK TOP
    USE 11012-1696 ACTIVE
    16126-1105 VALVE,AIR
    USE 16126-1043 ACTIVE
    44001-1584 FORK-FRONT
    44005-1233 PIPE-LEFT FORK OUTER
    44006-1233 PIPE-RIGHT FORK OUTER
    44013-1232 PIPE-FORK INNER
    44022-1182 CYLINDER-FORK
    44026-1303 SPRING-FRONT FORK,K=0
    44029-1120 SEAT-FORK SPRING
    44037-1183 HOLDER-FORK UNDER
    44039-1124 HOLDER-FORK UPPER
    92015-1055 NUT,8MM
    USE 92015-1398 ACTIVE
    FRONT MASTER CYLINDER
    120P0645 BOLT,SOCKET,6X45
    USE 120CA0645 ACTIVE
    132E0612 BOLT-FLANGED-SMALL
    USE 92002-1608 ACTIVE
    27010-1170 SWITCH,BRAKE
    USE 27010-0025 ACTIVE
    43015-1293 CYLINDER-ASSY-MASTER,
    43059-1305 HOSE-BRAKE
    43059-1306 HOSE-BRAKE
    43061-1056 JOINT-BRAKE
    USE 43061-1068 ACTIVE
    92002-1888 BOLT,OIL,L=23
    92037-1702 CLAMP,BRAKE HOSE,LH
    92037-1703 CLAMP,BRAKE HOSE,RH
    FRONT WHEEL/HUB
    41073-1315-J9 WHEEL-ASSY,FR,M.GRAY
    FUEL TANK
    130B0510 BOLT-FLANGED
    USE 130CA0510 ACTIVE
    OR 130AA0510 ACTIVE
    130B0550 BOLT-FLANGED
    USE 130AA0550 ACTIVE
    220B0308 SCREW PAN HEAD 3X8
    USE 220AA0308 ACTIVE
    221B0414 SCREW-CSK-CROS,4X14
    USE 221AA0414 ACTIVE
    702A07280 TUBE,RUBBER,7X10X280
    USE 702A071000 ACTIVE
    14069-1052 BREATHER,FUEL TANK
    51002-5080-H8 TANK-COMP-FUEL,EBONY
    51002-5088-H8 TANK-COMP-FUEL,EBONY
    51002-5089-H8 TANK-COMP-FUEL,EBONY
    51002-5090-7V TANK-COMP-FUEL,L.RED
    51002-5091-7V TANK-COMP-FUEL
    51023-1116 TAP-ASSY,FUEL
    51049-1065-10 CAP-TANK,FUEL,BLACK
    92059-1625 TUBE
    GEAR CHANGE DRUM & FORKS
    120P0616 BOLT,SOCKET,6X16
    USE 120CA0616 ACTIVE
    221B0645 SCREW-CSK-CROS,6X45
    USE 221AA0645 ACTIVE
    GEAR CHANGE MECHANISM
    130S0620 BOLT-FLANGED,6X20,BLA
    USE 130CB0620 ACTIVE
    172G0614 STUD 6X14
    USE 172BA0614 ACTIVE
    311G0600 NUT,6M/M
    USE 311BA0600 ACTIVE
    13242-1271 LEVER-ASSY-CHANGE,PED
    92001-1401 BOLT,RETURN SPRING
    USE 92001-1455 ACTIVE
    92022-1772 WASHER
    USE 92026-1532 ACTIVE
    13157-004 RUBBER CHANGE PEDAL ACTIVE LIMITED QUANTITY
    OR 92161-1532 ACTIVE
    GENERATOR/REGULATOR
    13091-1329 RECTIFIER
    USE 13091-1466 ACTIVE
    13091-1330 HOLDER,BRUSH
    13227-1054 HOUSING,GENERATOR
    21001-1106 GENERATOR
    21007-1123 ROTOR,GENERATOR
    21066-1056 REGULATOR-VOLTAGE
    USE 21066-1076 ACTIVE
    26011-1317 WIRE-LEAD,GENERATOR
    92002-1400 BOLT,8X32
    92015-1458 NUT,CAP
    92045-1132 BEARING-BALL,#6002
    92045-1237 BEARING-BALL
    USE 92045-1249 ACTIVE
    92055-1263 RING-O,67.6MM
    GENERATOR SHAFT/STARTER CLUTCH
    112G0616 BOLT-UPSET,6X16 ACTIVE LIMITED QUANTITY
    OR 112BA0616 ACTIVE
    115G0820 BOLT,8X20
    USE 115BA0820 ACTIVE
    120P0812 BOLT,SOCKET,8X12
    USE 120CA0812 ACTIVE
    315G1600 NUT-HEX-FINE
    USE 315BA1600 ACTIVE
    12046-1068 SPROCKET,GENERATOR
    13061-1111 BOSS,SPROCKET
    13061-1112 BOSS,COUPLING
    HANDLEBAR
    120S0830 BOLT-SOCKET,8X30,BLAC
    USE 120CB0830 ACTIVE
    220C0540 SCREW-PAN-CROS
    USE 220AB0540 ACTIVE
    220C0545 SCREW-PAN-CROS
    USE 220AB0545 ACTIVE
    46003-1198 HANDLE
    46091-1354 HOUSING-ASSY-CONTROL,
    46091-1373 HOUSING-ASSY-CONTROL,
    HEADLIGHT
    223D0410 SCREW-PAN-WS-CROS
    USE 223AA0410 ACTIVE
    223D0510 SCREW-PAN-WS-CROS
    USE 223AA0510 ACTIVE
    11044-1259 BRACKET,HEAD LAMP STA
    461F0500 WASHER SPRING 5MM ACTIVE LIMITED QUANTITY
    13091-1387 HOLDER
    23004-1188 LAMP-HEAD
    23005-1061-H8 BODY-COMP-HEAD LAMP,E
    23005-1061-7V BODY-COMP-HEAD LAMP,L
    23008-1281 SOCKET-ASSY
    28005-1053 BODY-LAMP
    92011-024 SCREW-PAN HEAD,5MM
    USE 92009-1947 ACTIVE
    92069-1002 BULB,12V-60/55W ACTIVE LIMITED QUANTITY
    IGNITION
    120P0825 BOLT,SOCKET,8X25
    USE 120CA0825 ACTIVE
    130G0512 BOLT-FLANGED
    USE 130BA0512 ACTIVE
    USE 92150-1599 ACTIVE LIMITED QUANTITY
    OR 132BA0612 ACTIVE
    21121-1135 COIL-IGNITION
    21121-1136 COIL-IGNITION
    92015-1078 NUT-6MM ACTIVE LIMITED QUANTITY
    92070-1019 PLUG-SPARK,DR9EA(NGK)
    USE DR8ES ACTIVE
    92070-1034 PLUG-SPARK,NGK D9EA
    USE D9EA ACTIVE
    IGNITION SWITCH/LOCKS/REFLECTORS
    120T0822 BOLT-SOCKET
    USE 120CA0822 ACTIVE
    236B0416 SCREW-PAN-WSP-CROS
    USE 236AA0416 ACTIVE
    461L0800 WASHER-SPRING
    USE 461DA0800 ACTIVE
    21007-5005 ROTOR,FUEL TANK
    USE 21007-5039 ACTIVE
    27004-5261 SWITCH-ASSY
    27010-1186 SWITCH,SIDE STAND
    27016-5087 LOCK-ASSY,SEAT
    LABELS
    56031-1399 LABEL-MANUAL,BATTERY
    56031-1425 LABEL-MANUAL,DAILY SA
    56031-1428 LABEL-MANUAL,OIL & OIL
    USE 56033-0067 ACTIVE
    56037-1306 LABEL-SPECIFICATION,T
    METERS
    23008-1279 SOCKET-ASSY,SPEEDOMET
    23008-1280 SOCKET-ASSY,TACHOMETE
    25001-1661 METER-ASSY,MPH
    25015-1238 TACHOMETER
    92009-1392 SCREW
    92022-1711 WASHER
    MUFFLERS
    18002-1592 BODY-COMP-MUFFLER,LH
    18002-1593 BODY-COMP-MUFFLER,RH
    18004-1052 CHAMBER-PREMUFFLER
    18049-1409 PIPE-EXHAUST,#1
    18049-1410 PIPE-EXHAUST,#4
    18069-1054 HOLDER-EXHAUST PIPE
    USE 18069-1122 ACTIVE
    39178-1120 MANIFOLD-COMP-EXHAUST
    39178-1099 MANIFOLD-COMP-EXHAUST
    49106-1067 COVER-MUFFLER,LH
    49106-1068 COVER-MUFFLER,RH
    49107-1066 COVER-EXHAUST PIPE,LH
    49107-1067 COVER-EXHAUST PIPE,RH
    92022-1716 WASHER
    92037-1536 CLAMP,MUFFLER
    USE 92037-1258 ACTIVE
    OIL PUMP/OIL FILTER
    132G0645 BOLT-FLANGED-SMALL
    USE 132BA0645 ACTIVE
    220B0612 SCREW PAN HEAD 6X12
    USE 220AA0612 ACTIVE
    220B0614 SCREW PAN HEAD 6X14
    USE 220AA0614 ACTIVE
    220B0620 SCREW PAN HEAD 6X20
    USE 220AA0620 ACTIVE
    221B0616 SCREW CNTSNK HD 6X16
    USE 221AA0616 ACTIVE
    92022-1495 WASHER,14X20X1
    USE 92026-1534 ACTIVE
    OWNER TOOLS
    56019-120 BOND,#10
    USE 1211 ACTIVE
    52005-1031 GAUGE,AIR,3.5KG/CM2
    USE 52005-1142 ACTIVE
    56007-1305 TOOLKIT
    92107-005 SCREW DRIVER #3 PHLIP
    USE 92107-1002 ACTIVE
    92107-1051 TOOL-DRIVER
    USE 92107-1052 ACTIVE
    RADIATOR/FAN/WATER PUMP
    130B0650 BOLT-FLANGED,6X50
    USE 130G0650 ACTIVE LIMITED QUANTITY
    OR 130BA0650 ACTIVE
    132J0612 BOLT-FLANGED-SMALL
    USE 132BB0612 ACTIVE
    157J0612 BOLT-WSP
    14024-1070 COVER,SCREEN,LH
    14024-1071 COVER,SCREEN,RH
    14024-1073 COVER,RH
    14024-1118 COVER,LH
    14037-1074 SCREEN
    14075-1062 CAP-ASSY,RADIATOR
    16160-1098 BODY,THERMOSTAT
    16160-1099 BODY,THERMOSTAT
    26011-1318 WIRE-LEAD,OIL TEMPERA
    27010-1188 SWITCH,WARNING
    27010-1191 SWITCH,OIL TEMPERATUR
    32033-1262 PIPE
    USE 39192-1029 ACTIVE
    32033-1712 PIPE
    39060-1064 RADIATOR
    39062-1124 HOSE-COOLING
    USE 39062-1220 ACTIVE
    39062-1126 HOSE-COOLING
    39062-1127 HOSE-COOLING
    39062-1128 HOSE-COOLING
    39062-1141 HOSE-COOLING
    39062-1142 HOSE-COOLING
    43056-003 BREEDER
    43078-1064 RESERVOIR
    49044-1058 PUMP-WATER
    USE 49044-1083 ACTIVE
    49054-1051 THERMOSTAT
    USE 49054-0003 ACTIVE
    49085-1053 CAP-ASSY-PRESSURE
    USE 49085-1066 ACTIVE
    59502-1058 FAN-ASSY
    92002-1550 BOLT,6X14
    92009-1288 SCREW,6X14
    USE 92009-1662 ACTIVE
    92027-1945 COLLAR ACTIVE LIMITED QUANTITY
    92037-1985 CLAMP,COOLING HOSE
    USE 92170-1284 ACTIVE
    REAR BRAKE
    41080-1113 DISC,RR,SILVER
    43034-1066 HOLDER-BRAKE,RR
    43041-1200 CALIPER-ASSY,RR
    43056-003 BREEDER
    REAR MASTER CYLINDER
    550D2015 PIN COTTER 2.0X15 ACTIVE LIMITED QUANTITY
    OR 550AA2015 ACTIVE
    43015-1292 CYLINDER-ASSY-MASTER,
    43059-1307 HOSE-BRAKE
    43059-1314 HOSE-BRAKE,RR,MASTER
    43078-1065 RESERVOIR,RR,MASTER C
    92022-1601 WASHER
    USE 92033-0079 ACTIVE
    92037-1535 CLAMP
    92037-1540 CLAMP
    92055-1251 RING-O ACTIVE LIMITED QUANTITY
    REAR WHEEL/HUB
    550D4035 PIN-COTTER,4.0X35
    USE 550AA4035 ACTIVE
    41073-1316-J9 WHEEL-ASSY,RR,M.GRAY
    42034-1011 COUPLING,REAR HUB
    USE 42034-0002 ACTIVE
    ROCKER ARMS/VALVES
    12016-1051 ARM-ROCKER
    USE 12016-1126 ACTIVE
    16007-1144 SEAT-SPRING
    USE 16007-1178 ACTIVE
    16007-1143 SEAT-SPRING
    USE 16007-1177 ACTIVE
    SEAT
    130B0612 BOLT
    USE 130G0612 ACTIVE LIMITED QUANTITY
    OR 130AA0612 ACTIVE
    130B0625 BOLT,FLANGED,6X25
    USE 130AA0625 ACTIVE
    223B0510 SCREW-PAN-WS-CROS
    27012-1332 HOOK,SEAT LOCK
    32046-1236 BRACKET-SEAT
    32085-1167 STOPPER,SEAT
    46102-1150 ROD,SEAT STAND
    49031-1051 LATCH,SEAT
    53001-1426 SEAT-ASSY,FR
    53001-1427 SEAT-ASSY,RR
    53003-1139 LEATHER,SEAT
    53003-1140 LEATHER,SEAT
    53009-1057 HINGE,SEAT
    53009-1058 HINGE,SEAT
    59071-1104 JOINT,SEAT STAND
    92002-1596 BOLT,* ACTIVE LIMITED QUANTITY
    92043-1289 PIN,6X68
    92081-1664 SPRING,SEAT
    SHOCK ABSORBERS
    11012-1478 CAP,AIR VALVE
    USE 11012-1469 ACTIVE LIMITED QUANTITY - These are no longer CHROME, they are BLACK
    45014-1352 SHOCK ABSORBER
    SIDE COVERS
    224C0635 SCREW-PAN-WP-CROS ACTIVE LIMITED QUANTITY
    224C0640 SCREW-PAN-WP-CROS
    11044-1258 BRACKET,SIDE COVER
    36001-1301-H8 COVER-SIDE,RH,SUB,EBO
    36001-1301-7V COVER-SIDE,RH,SUB,L.R
    36002-5080-H8 COVER-SIDE,LH,EBONY
    36002-5080-7V COVER-SIDE,LH,L.RED
    36002-5081-H8 COVER-SIDE,RH,BATTERY
    36002-5081-7V COVER-SIDE,RH,BATTERY
    92009-1663 SCREW
    OR 92009-3805 ACTIVE
    STAND
    34024-1217 STAND-SIDE
    STARTER MOTOR
    OR 132BA0612 ACTIVE
    461F0600 WASHER SPRING 6MM
    USE 461DA0600 ACTIVE
    16085-1119 GEAR,IDLE
    21040-1051 SPRING-BRUSH
    USE 21040-0001 ACTIVE
    21163-1081 STARTER-ELECTRIC
    26011-1332 WIRE-LEAD,STARTER MOT
    92002-1377 BOLT
    OR 92015-2058 ACTIVE
    OR 92210-0630 ACTIVE
    92015-1457 NUT,6MM
    92022-1622 WASHER-SPRING
    92022-1623 WASHER
    92071-1134 GROMMET,TERMINAL
    SWING ARM
    130P0620 BOLT-FLANGED,6X20 ACTIVE LIMITED QUANTITY
    OR 130CA0620 ACTIVE
    OR 130BA0620 ACTIVE
    OR 130AA0620 ACTIVE
    OR 130CA0620 ACTIVE
    315B1200 NUT-HEX-FINE,12MM
    USE 315AA1200 ACTIVE
    32085-1212 STOPPER
    33001-1244 ARM-COMP-SWING
    33032-1117-AA SHAFT-SWING ARM,"A"SI
    33032-1117-BB SHAFT-SWING ARM,"B"SI
    33032-1117-CC SHAFT-SWING ARM,"C"SI
    33032-1117-WW SHAFT-SWING ARM,"W"SI
    33032-1117-XX SHAFT-SWING ARM,"X"SI
    33032-1117-YY SHAFT-SWING ARM,"Y"SI
    33032-1117-ZZ SHAFT-SWING ARM,"Z"SI
    33032-1119 SHAFT-SWING ARM
    92009-1388 SCREW,SOCKET,12X25
    TAILIGHT
    220C0420 SCREW-PAN-CROS,4X20
    USE 220AB0420 ACTIVE
    13091-1379 HOLDER,LICENSE
    23008-1271 SOCKET-ASSY,LICENSE L
    23016-1065 LAMP-ASSY,LICENSE
    23026-1068 LENS,TAIL LAMP ACTIVE LIMITED QUANTITY
    23026-1069 LENS,LICENSE LAMP
    23027-1062 BODY-COMP-TAIL LAMP
    USE 23025-1123
    ACTIVE
    92015-1078 NUT-6MM
    OR 92015-2058ACTIVE
    OR 92210-0630ACTIVE
    92027-251 COLLAR
    OR 92152-0365 ACTIVE
    TIRES
    41002-1513 TIRE,FR,100/90-18 56H
    41002-1612 TIRE,RR,160/80-15 74H
    41075-1014 BALANCER-WHEEL,10G
    USE 41075-0014
    ACTIVE
    41075-1015 BALANCER-WHEEL,20G
    USE 41075-0015
    ACTIVE
    41075-1016 BALANCER-WHEEL,30G
    USE 41075-0016
    ACTIVE
    TRANSMISSION
    13129-1533 GEAR,INPUT TOP,28T
    13129-1700 GEAR,OUTPUT 2ND,38T
    13129-1701 GEAR,OUTPUT 3RD,35T
    USE 13129-1775
    ACTIVE
    13129-1702 GEAR,OUTPUT 4TH,32T
    USE 13129-1776
    ACTIVE
    13129-1703 GEAR,OUTPUT 5TH,30T
    13129-1704 GEAR,OUTPUT TOP,29T
    92022-1077 WASHER,LOCK (O.D=35)
    USE 92024-042
    ACTIVE
    92022-1692 WASHER,20.3X32X4.5
    92045-1186 BEARING-BALL
    USE 92045-1413
    ACTIVE
    TURN SIGNALS
    23037-1219 LAMP-ASSY-SIGNAL,RR
  2. Raf900
    Raf900 Member
    27
    13
    I have a 86 with the wing emblem on the tank. are there any out there unused?
