Clutch and brake master cylinders.
Rob2018 May 5, 2019
  1. Rob2018
    Rob2018 New Member
    7
    Ive done my own research but cant find anything defonite. I need to replace both but want to be sure i get the right set. Any sellers, links, or tips?
  2. prfixer
    1,534
    80
    Find the best used set you can find from an 86-06 Concours.
    625
    :hello: It you want new a seller has a NOS brake master cyn listed on E bay for $150. You will find it listed under EL 250. Kawasaki still sells the rebuild kits for both the clutch & brake master cyns. From partzilla the cost is about $43 for each. You will also need the 2 outer dust caps that go between the levers and the master cyns. About $5 each. Also I remember a member bought new sight windows but he did not give any details. IMG_7311.JPG
  4. prfixer
    1,534
    80
    Are you sure the EL250 master works on the bigger bikes? the 250 only had one disk.
    625
  6. prfixer
    1,534
    80
    They take different rebuild kits as well.
    625
    :hello: I seen that. The 250 kit seems to have smaller orifices so most likely it will not move/circulate brake fluid as fast as the ZL 9/10 brake master cyn so one would think. Or maybe circulation volume is not a factor.
