CDI igniter to ZL1000
LUMI Mar 31, 2009
  1. LUMI
    LUMI Senior Member
    111
    i have been looking for CDI to ZL1000 part number 21119-1202 but have not found :help:
    will ZL900/Concours 21119-1111, 1110 igniter or GPZ1000RX 21110-1165, 1164 work on ZL1000 ?
  2. kawboy
    Markus56 just put a Conc motor in his ZL900 - what ignitor did y'all use?
  3. zlMark
    zlMark Cult Leader
    8,935
    126
    121
    stock zl900 for now, cause we forgot to change it. Mark is supposed to test it for a bit then swap to see the difference if any.
  4. kawboy
    After re-reading the original post, Lumi says the ZL900 and Conc has the same igniter, which is correct. So the Markus swap won't tell us anything.
    Sorry, I can't answer your question Lumi. The difference in the 900/1000 may simply be the connector or the case. Maybe someone who has both bikes will be brave enough to swap and see :laughing7:
  5. markus56
    2,998
    106
    I still have the zl900 cdi in the bike but the zl1000 cdi I have going in is different and unique to the zl1000. It has a different timing advance to it I believe. As Mark said, I will be testing to see if I can feel any difference.
  6. zlMark
    zlMark Cult Leader
    8,935
    126
    121
    It will work I know of one zl1000 with a ignitor from a zx/zg/zl900. The only difference he reported was higher rpm capability before cutting out
  7. LUMI
    LUMI Senior Member
    111
    OK thanx, this is enough for mee, ill buy ZL900 CDI for it
  8. MikeC
    MikeC Senior Member
    245
    Markus56, Did you ever notice a difference in the zl1000 with alternate zg1000 or zl9 igniters? I got a bad one I'm pretty sure. A few readings in spec and a few way out.
  9. kawboy
    FYI - in the service manual, on the table for testing the igniter, the +/- polarity labels are incorrect (backwards).
    Also, the readings in the table are with the "Kawasaki Hand Tester". Your meter will likely not get the same exact readings.
  10. MikeC
    MikeC Senior Member
    245
    Ok, well the spec shows a max 55k ohms and I have 8M ohm on one reading and reversed leads show O.L. but others show 4kohm either way the leads are oriented, which are within. I have a no spark condition in 1 and 4. Coils test within. Brand new battery. New ignition wires and plug caps rebuilt. Not much left here so I'm getting closer...
  11. 87kawzl
    87kawzl Well-Known Member
    1,169
    59
    93
    May want to look at the pickup
  12. kawboy
    I've never had any luck matching the readings in the test table, even with known good and brand new igniters.
  13. MikeC
    MikeC Senior Member
    245
    Well that sucks. How can you rule it out, but to replace it?
  14. 87kawzl
    1,169
    59
    93
    I think you can test the pickup coil. Look for proper gap and brolen wires where it goes through the case.
    Double check the studs on the coils for tightness and proper grounds of coil to frame.
  15. MikeC
    MikeC Senior Member
    245
    Ok thanks
  16. MikeC
    MikeC Senior Member
    245
    Just wanted to tell this story from the beginning to see if anyone sees something I don't.
    So i took the dust cover off after sitting for 6 years charged the battery (as if it was going to start) and cranked it. Discovered I had no spark. Checked the zloa website, pulled and re built the plug wires and caps all new. Had spark in 2 and 3,no spark 1 and 4. Pulled coils cleaned terminals and walaa I had spark. Sent the carbs too Rick, installed them, no spark 1 and 4 BUT It would crank in neutral without clutch. Then it wouldn't crank in neutral without the clutch. Checked the kickstand switch. I feel like this is connected...
  17. RLTherio
    RLTherio Active Member
    290
    15
    What condition is the battery?
  18. MikeC
    MikeC Senior Member
    245
    Brand new
  19. MikeC
    MikeC Senior Member
    245
    Is there supposed to be oil in the area of the pickup coils ? If not I've found the problem.
  20. 87kawzl
    1,169
    59
    93
    Oil finds its way in there. Always a little when you take that cover off
