carb's from rick west!
1 red zl9 Nov 10, 2012
  1. Scoobys_piece
    2,026
    Do you offer commission?:rotf: I turned REDDOBIE and 1REDZL9 (both new users) onto you...maybe handicapped discount:rotf::rotf::rotf: All you need to do is look at your work and it's kinda a no brainer.
  2. jmassengill
    jmassengill Supporting Member Technical Author
    987
    The peace of mind gained by sending carbs to Rick is well worth EVERY dime spent!
    I toyed around with rebuilding the carbs on my ZX600 myself but I knew if they gave me problems I would always wonder about them...SOOOO off to Rick they went!
  3. reddobie0
    reddobie0 Well-Known Member
    425
    Had two sets of carbs done by Rick. Awesome work would highly recommend. Basically get back from Rick put on and purrs like a kitten runs like a cheetah..:notworthy:
  4. 1 red zl9
    1 red zl9 Well-Known Member
    1,157
    sooooo easy! post 19. hmmmmm
  5. wickedzl900
    wickedzl900 Senior Member Supporting Member
    372
    31
    123
    lol, sometimes not
    399
    :hello: Found this thread. This would be a great place to post comments about Ricks work after installing carbs that he done for us. Martin it might be a good idea to move all the latest posts in Ricks CARB SERVICE thread to here. :notworthy:. It will give you some practice. :laughing7:
  7. wickedzl900
    372
    31
    123
    i will work something out for you.. appreciate the recomendations
    399
    :hello:Rick I reinstalled my carbs on my ZL 10 that you done for me last June. I did the eye ball look through out side up to God :laughing7: & the paper test to by using 4 each 1/4 inch wide pieces of paper about 4 inches long. The tention when pulling the paper out all seemed to be the same so I left the bench sync as you done them. My tank, fenders & side covers $350 :notworthy: are at my painters John Kelly. Also I'm doing some preventive maintenance. I'll give you heads up later when I'm done with my bike. Thanks. :notworthy:.
